First oil change...Part 2. Liter or Quart?
Results 1 to 7 of 7
Like Tree3Likes
  • 1 Post By Peterb
  • 1 Post By TW-Brian
  • 1 Post By RockyTFS
Thread: First oil change...Part 2. Liter or Quart?
    Senior Member Cerberus's Avatar
    Aug 2018
    San Diego, CA
    149
    Just got a gallon of Yamalube 10-40.
    It has markings for Liters and Quarts. Should I use a Liter or a Quart? There is a difference. Thank you.
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,485
    I think its embossed "1000 ml" right near the fill plug. So to answer your question it takes one litre (that is how it is spelled in Canada)
    ejfranz likes this.
    Pleasanton, CA
    5,777
    You are correct 1 quart = 946 milliliters, or slightly less a full liter.
    With your bike on level ground and as close to vertical as you can safely secure it, just slowly add oil until it begins to be visible in the sight glass in the lower right side engine cover. Then I usually start my engine and let it run for a minute or two, then shut it down and top off the oil level to the top mark on the sight glass.
    Darth likes this.
    Hailey, ID
    3,404
    I use 1 quart. However, the difference between a liter and a quart is not enough to cause a problem. When I buy oil in gallons I get a used quart oil bottle and fill it to the mark, then dump it in to avoid any overfill. You can also use a kitchen 1 quart beaker, just don't tell the wife! I have several tools that need only 250 to 400 milliliters of oil, so I eventually bought a dedicated plastic beaker for that purpose. Pouring in an exact amount of oil makes the procedure simpler.
    Mel likes this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Aug 2018
    San Diego, CA
    149
    Thank you all, much appreciated.
    Junior Member KLRCris's Avatar
    Nov 2018
    25
    The wife will never know as long as you wash it out and put it back in the cupboard.
    Hailey, ID
    3,404
    My wife would....she has ESP.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
  1. Mobil1 Racing 4T for $7.28 per Quart on eBay Free Shipping
    By Badgerflorida in forum TW200 Classifieds
    Last Post: 10-24-2018, 04:52 PM
  2. ***SOLD***Selling Happy Trail 47 liter aluminum top box
    By acjlarsen in forum TW200 Classifieds
    Last Post: 11-01-2014, 05:21 PM
  3. First oil change, now a tapping sound
    By Mac313 in forum Technical Help
    Last Post: 09-11-2013, 10:04 PM
  4. first oil change, quick question
    By russ5415 in forum Technical Help
    Last Post: 02-13-2013, 11:25 PM
  5. Liter bikes
    By flash in forum Off-Topic
    Last Post: 04-20-2012, 07:29 AM
