First oil change...part 3
Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By RockyTFS
Thread: First oil change...part 3
    Senior Member Cerberus's Avatar
    Aug 2018
    San Diego, CA
    149
    Got thru the oil change without problems. When it was time to check the weep bolt I had no idea what to expect as far as how much oil would seep out so after running the engine for a couple of minutes and seeing nothing come out I got worried, turned off the engine and completely removed the bolt and it was completely coated with clean oil, so I’m assuming everything is ok. Should I have waited longer? As I said I had no idea what to expect. Thank you all for your help.
    Hailey, ID
    3,405
    That's what the paper towel is for: it makes it much easier to see the first drop wick out. Also, if you run the RPM's up a little bit, it will take less time.
    I hope you have been reading the cover bolt advice not to use the specified torque, but about 15% less so as not to stretch or snap the bolts.
    Since I re-use the original oil filter indefinitely, and NO-ONE works on my bike but me, I have stopped doing the bleed test since there is no possibility of putting in the wrong filter. The ONLY possibility is that I actually forget to put fresh oil in and maybe someday when I'm even more senile I'll do that!
    Dryden-Tdub likes this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Aug 2018
    San Diego, CA
    149
    Thank you. That’s insurance enough for me as I’ll be the only one to change the oil. Yes I’ve read about the bolts and while I do not own a torque wrench I’ve always had a good feel for when it’s far enough. I haven’t snapped a bolt so far in more than 50 years of oil changes. Thanks again.
  1. First oil change...Part 2. Liter or Quart?
    By Cerberus in forum Technical Help
    Last Post: 12-19-2018, 09:48 PM
  2. First oil change at 100 miles today holy metal shavings
    By Holdnon72 in forum General Discussion
    Last Post: 03-01-2014, 09:57 AM
  3. First oil change, that I've done. Check out my filter
    By Little General in forum Technical Help
    Last Post: 09-14-2013, 11:37 AM
  4. First oil change, now a tapping sound
    By Mac313 in forum Technical Help
    Last Post: 09-11-2013, 10:04 PM
  5. first oil change, quick question
    By russ5415 in forum Technical Help
    Last Post: 02-13-2013, 11:25 PM
