2003 TW200 Won't Start; Has spark
Results 1 to 10 of 11
Like Tree9Likes
Thread: 2003 TW200 Won't Start; Has spark
    Junior Member MCB's Avatar
    Nov 2018
    9
    I have a 2003 TW that refuses to start. It was running fine until it suddenly stopped at a stop light. We diagnosed it and found that it had no spark, but after replacing the magneto/stator yesterday we were able to get a visible spark. However, it still isn't starting. It has a new lithium battery we got a little over a month ago. Voltage tests show that its working fine, and we've tried bump starting and jump starting from another battery. We tried starter fluid, and still nothing. Air presses on my finger when holding over the spark plug hole and trying to start it, and it smells of fuel and trips from the carb after the petcock has been left open for a few minutes, so it seems that it has all three elements of spark, fuel, and compression. This bike has had a history of being difficult to start. We're going to go get a compression tester later this after to confirm that we have compression, but after that I'm not sure what to do. Any suggestions would be greatly appreciated!
    Ken likes this.
    Mar 2015
    Ynys Môn
    4,631
    Quote Originally Posted by MCB View Post
    trips from the carb after the petcock has been left open for a few minutes !
    Should drip from the carb in seconds - and if it takes a minute or two before dripping when not running with none of the bleed screws open, then you have a problem with the carb
    That's your starting point - fuel supply
    Either the petcock, or the carb itself .....
    elime and Ken like this.
    - Hidden Content
    Nov 2018
    9
    I thought carb issues might have been eliminated when it didn't fire up for a few seconds with with the starter fluid. Is that not the case? If so, do you think I need to do a full carb cleaning?
    Thanks for your response.
    Ken likes this.
    Tennessee
    1,301
    Could still be a weak ignition coil or weak plug. Could be air filter. Could be fuel quality or supply. Slight chance it's CDI but I think a failing CDI can still start up sometimes. It could be more serious like a messed up valvetrain, cam chain tensioner or very low compression, but those are much less likely to occur at a stoplight unless you were low on oil or had crazy high miles/weird noises and maybe no valve adjustment ever. Just unlikely any of the serious ones like that would happen without warning. What does the spark look like and where did you spray the starter fluid? A better test may be a teaspoon or so of fuel in the spark plug hole. If the fuel was running low it's very possible that something got sucked in and is obstructing fuel delivery. Occasionally folks only find out they were low on fuel when they pull the clutch in or come to a stop and the bike dies. Did it die as you stopped or while stopped?
    Ken likes this.
    Jan 2017
    Southern Nevada
    1,077
    A. How bright is the spark? Bright white/blue, not yellowish?
    B. What is spark plug gap? Under compression, a wide gap may not fire.
    C. How new is the spark plug?
    D. What is color of spark plug?
    E. Has any work been done on the timing chain?
    F. What were voltage tests? (1) Key off? (2) Key just turned on? (3)While trying to start?
    G. Choke/enrichener on or off?
    H. What is setting of mixture screw? Is it open to about 2 1/2 turns from gentle seat?
    I. Air filter removed to squirt ether? How much ether? One second blast while cranking?
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,130
    Check all the safety switches. Kill switch, neutral switch, kick stand switch and also all the various ground wires behind the head light, most are black. Any of these switches that fail will cause the bike to not run even if you do see spark at the plug. They are all interconnected into the light box beside the speedometer.
    goldenhtr and philo like this.
    1987 Yamaha BW350 Big Wheel
    6,999
    Sounds flooded. Turn the gas OFF and hold the throttle WIDE OPEN and see if it starts. If it does then it is a carb problem.
    Senior Member tombauer's Avatar
    Jun 2017
    Sadly, Maryland
    153
    needs new plug
    excalibur likes this.
    Junior Member 100000 miles's Avatar
    Jul 2018
    FL OK
    28
    This might sound stupid (because it is) but I had pulled the plug on mine to check spark and simply failed to plug the wire in completely when I reinstalled the plug. The spark plug wire "clicked" once and seemed like it was seated but it was not. The spark checked OK when I tested it but obviously the bike wouldn't run when I tried to start it.
    I just had to push harder to force a more solid click and it worked fine.
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,958
    I had something similar happen on my 1993 before. 1st double check the kill switch. I have bumped them off at lights before. The odd thing I did which seemed to work was to push it lightly with the clutch engaged, not held in, and just lightly bump it a couple times. Then put it in neutral and try starting it. After I made it home I would tighten my cam chain adjuster. I always suspected that the cam chain was a little loose which may have had the timing off just a tad. All I know was I got it started after it died at the light doing that method. It happened a handful of times. If it has been consistently been getting harder to start your valves may be going bad so the compression test you mentioned is the way to go. Good luck.
  1. No electrical at all, won't start, will bump start
    By jgaff in forum Technical Help
    Last Post: 08-10-2017, 02:06 PM
  2. Won't Start - Lights all die when start engaged
    By vuldub in forum Technical Help
    Last Post: 09-14-2016, 10:39 PM
  3. Replies: 3
    Last Post: 06-16-2015, 12:07 AM
  4. Have spark and fuel but won't start
    By Jemo in forum Technical Help
    Last Post: 06-16-2012, 09:59 AM
  5. kick start won't start
    Last Post: 01-15-2011, 06:23 AM
