Starter switch fix
Results 1 to 9 of 9
Like Tree5Likes
  • 1 Post By SportsterDoc
  • 1 Post By Gastone165
  • 2 Post By Kykdaar
  • 1 Post By Kykdaar
Thread: Starter switch fix
    Junior Member Kykdaar's Avatar
    May 2017
    South Africa
    7
    Starter switch fix
    Hi there
    Is there a way to fix the starter press switch when the two contacts seems to be so worn that they no longer make contact?
    Seems an idea might be to either cut the spring a little bit or try build up one of the contact surface areas somehow.
    Anyone did a DIY and can share some advice?
    Thanks
    Jan 2017
    Southern Nevada
    1,077
    What year TW?
    Most likely not worn, but contacts may be corroded.
    There is not enough current across them to burn them as do the stater solenoid contacts.
    What is the resistance across the switch?
    Have you opened the switch?
    Is there any doubt that the circuit may be open, other than the switch?
    Fred likes this.
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    19,045
    Careful inspection, cleaning and reassembly often can restore functionality of most of these TW switches.
    May 2017
    South Africa
    7
    Quote Originally Posted by SportsterDoc View Post
    What year TW?
    A 2003 model
    I have opened it up, not corroded or burnt, but it seems as if the fully compressed spring prevents the two points from making contact hence the thought that one or both may have worn over time to the point where they can no longer close the circuit.
    Have checked the rest of the starting circuit as per manual and everything else is in spec, including the start relay.
    Bike has a kickstart as well (comes standard that way in South Africa), but would like to get the happy button to work again.
    Will re-size pics and post
    Dec 2017
    Western Washington
    217
    Kykdaar, not to change the subject of the post, but you mentioned TWs come with a kickstarter in South Africa. Does that include the current new models? If that’s true, then Yamaha would still be making the kickstarter parts, but just not importing them to the U.S.
    Interesting...
    Now they’ll have to watch for Yamaha Parts smugglers at the airport.
    Ken likes this.
    1972 Yamaha DT 175, 1974 Kawasaki 125, 1976 Suzuki TM 250, 1979 Yamaha 750, 1977 Husquvarna 360, 1979 Husquvarna 250, (2) 1980 Suzuki RM 400’s, 1971 Husquvarna 400, 1983 Honda V65 Magna, 1987 Suzuki 230 Quad, 1987 TW200, 1990 TW200, 1996 Honda XR 650, 1998 Yamaha 300 King Quad, 2000 Harley Davidson Heritage, 2006 Kawasaki KLX 250s, 2007 Arctic Cat 650 Quad, 2010 Polaris Sportsman 850 Quad, 2006 Yamaha Grizzly 660 Quad, 2002 TW200, 1995 TW200, 2008 TW200, 2016 TW200.
    May 2017
    South Africa
    7
    Quote Originally Posted by Gastone165 View Post
    Interesting...
    Interesting - it seems the latest model on Yamaha South Africa's website is sans kickstarter
    http://www.yamaha-motor.co.za/tw200/
    Will try find out when this happened - they usually had kickstart and e-start
    Miaugi and Ken like this.
    May 2017
    South Africa
    7
    Folowing the trail -
    A 2004 model locally and my old 2010. Both with front disc and kickstart
    Mel likes this.
    May 2017
    South Africa
    7
    So just to wrap on the starter switch issue - at the end of the day I just lifted the bottom connector out of its plastic recess, flipped it around and re-inserted it back.
    As the bottom connector has a collar that resides in the plastic switch housing it worked without a problem - long side now facing upwards and now easily makes contact with the top connector when slightly pressed.
    Bike start first slight push on the starter switch - happy days
    Attachment 187950
    Jan 2017
    Southern Nevada
    1,077
    Good fix.
    2014 Honda CB1100
    2018 Yamaha XT250
    2017 Yamaha TW200
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
  1. Fix one find one to fix - Cam Sprocket Replacement?
    By Soulprogression108 in forum Technical Help
    Last Post: 11-27-2018, 03:25 AM
  2. Starter Wouldn't Crank - Unexpected Cause, Easy Fix
    By BkCntryCrwlr in forum Technical Help
    Last Post: 12-15-2017, 06:54 PM
  3. Key ignition switch to Toggle switch - Anyone do this?
    By Skin Walker in forum Performance and Customization
    Last Post: 04-13-2017, 09:56 PM
  4. Kill Switch, Kickstand Switch, Clutch Switch
    By twmonae in forum Technical Help
    Last Post: 08-16-2010, 07:50 AM
