Source Coil Resistance damage
Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By Peterb
Thread: Source Coil Resistance damage
    Junior Member elkraken's Avatar
    Sep 2016
    9
    Hello friends!
    My motorcycle turned off and I can not turn it on again, I opened the motor to check the stator, and I checked the resistances of the source coils, charge coil, and pickup coil.
    the source coil of my tw200 nc 2001 does not show resistance.
    my question is: can I send power from the battery to the CDI directly so that my motorcycle turns on?
    The other coils are within the range set by the manufacturer.
    thanks for your help!
    Greetings from Mexico
    19,069
    Lo siento,mala suerte. I believe a working stator is required to feed power to your CDI and ignition coil, otherwise no spark. Others can give more accurate diagnostic info but depending on the year your source coils should have about 400 to 450 ohms. No resistance means a short circuit.
    Sep 2016
    9
    Thanks for your reply,
    I think the only option is the replacement, there is no visible damage, but reading in my multimeter in null.
    I wish you a safe ride always.
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,488
    Are you sure you have your ohmmeter on the correct scale? No resistance would indicate a shorted coil (zero ohms) . Infinite resistance would indicate and open circuit.
    Fred likes this.
  1. Source Coil Wiring to CDI - GY6 CDI Troubles
    By Oleschool in forum Technical Help
    Last Post: 08-17-2015, 09:14 AM
  2. Questions about stator source coil testing for 88 TDub
    By JustSomeDude in forum Technical Help
    Last Post: 03-02-2014, 09:56 PM
  3. 1987 Pulse Coil Resistance To Earth?
    By Lee_Hewitt in forum Technical Help
    Last Post: 11-30-2013, 03:41 AM
  4. How to check STATORS ohm RESISTANCE???
    By craig c in forum Technical Help
    Last Post: 11-05-2013, 07:03 PM
  5. Panniers and Wind Resistance
    By retmotor in forum General Discussion
    Last Post: 08-26-2012, 04:23 PM
