1157 LED Bulb - Dual Function 27 SMD LED Tower - BAY15D Bulb - Red
Results 1 to 8 of 8
Like Tree4Likes
  • 1 Post By SportsterDoc
  • 1 Post By Fred
  • 1 Post By RaZed1
Thread: 1157 LED Bulb - Dual Function 27 SMD LED Tower - BAY15D Bulb - Red
    Senior Member Cerberus's Avatar
    Aug 2018
    San Diego, CA
    149
    I’d like to have a more visible brake light for safety. The ProCycle tail light bulb supposedly only uses 1 volt and is three times as expensive with shipping. Would the above bulb use the same amount of energy? $13including shipping. I looked at the specs but I know nothing about automotive electrical. Thank you for your help.
    Jan 2017
    Southern Nevada
    1,077
    Quote Originally Posted by Cerberus View Post
    1 volt or 1 amp or 1 watt for stop?
    1157 incandescent uses 2.2 amps for stop.
    For household use, a 60 watt equivelent CFL is 13 watts and a LED ~8 watts...for a rule of thumb, the same illumination of an LED is roughly 1/8 of the current draw of an incandescent.
    Do you have a link for "the above bulb"?
    For a visibility comparison, check candlepower or lumen output.
    1157 low filament for tail and license is 8.26 watts, 38 lumens, 3 candlepower
    The high filament is 26.8 watts, 402 lumens, 32 candlepower.
    Check this web https://www.superbrightleds.com/sear...ake-turn/1157/
    I got the TW flasher for LEDs from them and many other items.
    Peterb likes this.
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    19,023
    If you can't find the lumen output at least go for the largest chip set. For example it took me about 15 seconds to readily find a 54 SMD with projector lens vs. the 27 SMD originally mentioned.[Sponsored]ENDPAGE 1157 2057 2357 7528 BAY15D LED Bulb 2-pack, Amber Yellow, Extremely Bright, 54-SMD with Projector Lens, 10-30V, Work as Turn Signal Blinker Lights.
    Not saying to buy these but pointing out that superbright and precycle have very limited offerings compared to the vast options one can find with just a bit of research, often superior newer designs at significantly better prices too.
    However most any of the LEDs will seem appreciably brighter than the OEM incandescent 1157 bulbs. I suggest getting LED replacements for all your bikes bulbs as well as all your other vehicles bulbs.
    buellzebub likes this.
    Jan 2017
    Southern Nevada
    1,077
    Also best to use white, rather than red:
    1. They are usually brighter
    2. White will properly illuminate the lucense plate
    Smitty Blackstone likes this.
    2014 Honda CB1100
    2018 Yamaha XT250
    2017 Yamaha TW200
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Aug 2018
    San Diego, CA
    149
    Quote Originally Posted by SportsterDoc View Post
    Thank you, the link is the same one you sent me.
    Jan 2017
    Southern Nevada
    1,077
    OK, no lumen output info, so heed Fred's comments in post 3.
    2014 Honda CB1100
    2018 Yamaha XT250
    2017 Yamaha TW200
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Senior Member RaZed1's Avatar
    Oct 2015
    297
    It will also make your taillight pink and washed out. From a distance it looks virtually white.
    Several companies make LED 1157's with a built in strobe effect. I have one by "Alla Lighting" in my Valkyrie. I think a 2 pack was $20 on fleabay. Red LEDs and easily twice the brightness of the original bulb. Plus when you first apply the brake it strobes 3 or 4 times before lighting steady. Very attention grabbing.
    Take claimed lumens with a grain of salt. They're often hugely exaggerated, and have little relevance to perceived brightness. The lower the quality, the more BS the claims.
    Fred likes this.
    Feb 2017
    Waretown NJ
    556
    I bought 1157 leds. The housing is too big and I can't get the bulb to twist tight.
    I can't use Led lights on the front or rear of my 87
    87 TW
  1. Replies: 5
    Last Post: 08-07-2016, 03:58 PM
  2. Fire Tower Ride
    By Rickhem in forum Trails, Off-road, and Adventure Riding
    Last Post: 06-08-2016, 03:05 PM
  3. Tower to Lake Bottom Ride, a Hi-Lo Video
    By Fred in forum Trails, Off-road, and Adventure Riding
    Last Post: 09-11-2015, 08:30 PM
  4. carburetor red red ?
    By harvey in forum Technical Help
    Last Post: 10-31-2014, 10:07 AM
  5. Stator Function
    By jmurray in forum Technical Help
    Last Post: 07-12-2011, 10:10 AM
