Need bulb part #
Results 1 to 5 of 5
Like Tree4Likes
  • 3 Post By YamTW87
  • 1 Post By RaZed1
Thread: Need bulb part #
    Senior Member TW Newb's Avatar
    Dec 2018
    Los Angeles
    184
    The high beam indicator light isn't working. Would like to order before pulling it apart. Manual states wattage but no part number.
    Probably switch to led.
    I think it might be a BA9s?
    Also would like to confirm what bulbs the speedo uses too. Thanks!
    Me thinks its a 194?
    2001 TW
    Senior Member YamTW87's Avatar
    Mar 2017
    Greece
    157
    Yes,indicators are BA9s 3.4w and speedo is T10 3.4w.
    Exact part number for indicator is 123-83516-21-XX and speedo is 4G1-84744-00-XX ,but i would use LED ones instead.
    Also,here is a video to help you with your installation,in case you need it.
    Fred, Badgerflorida and Sthrnromr like this.
    Dec 2018
    Los Angeles
    184
    I found that BA9s number in the comments of that video lol. Just figured I'd confirm here. Thanks!
    2001 TW
    Senior Member RaZed1's Avatar
    Oct 2015
    297
    The speedo takes a standard 194 wedge base bulb. The three indicator lights are the BA9 mini bayonet's.
    If you go with LEDs, match the LED to the lens color. So get a blue LED for the high beam, green for neutral/turn, red for tail/brake, ect. White LED's(particularly the "cool" or "bright" hues) tend to "wash out" lens color.
    I went with a "warm white" LED for the speedo, which is similar in hue to the regular bulb just a lot brighter.
    Avoid the super cheapo ebay LED bulbs. Poor quality and they tend to start flickering/crap out pretty quickly. I get them from superbrightleds.com and always had good results.
    Badgerflorida likes this.
    Senior Member Miaugi's Avatar
    Oct 2017
    Alfred, On
    463
    Quote Originally Posted by RaZed1 View Post
    ... I get them from superbrightleds.com and always had good results.
    By chance could you post up the exact numbers you went with? I looked around at Superbrightleds however there seems to be a plethora of options and I didn't end up ordering anything yet. Thank you!
  1. Replies: 7
    Last Post: 01-07-2019, 08:24 PM
  2. Replies: 18
    Last Post: 02-22-2017, 06:54 PM
  3. Can't find replacement part after crash(x2), odd part?
    By pdaddy in forum General Discussion
    Last Post: 08-15-2015, 09:28 PM
  4. bulb list
    By accor415 in forum Technical Help
    Last Post: 12-21-2010, 07:35 PM
  5. turn signal, right rear, "quick" flashing, good bulb
    By flybill59 in forum Technical Help
    Last Post: 09-12-2010, 10:46 PM
