Rear whel axle bolts.
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Like Tree35Likes
Thread: Rear whel axle bolts.
    Senior Member Cerberus's Avatar
    Aug 2018
    San Diego, CA
    149
    I'm going to attempt adjusting the chain's slack, I have not measured yet but it looks pretty slack after 300 mi. I have the 19mm socket for the left side but not a 22mm for the right side. I do have a 7/8" which fits with just a bit of play..I'm I risking rounding out that bolt? Thank you for your help.
    Badgerflorida likes this.
    Mar 2011
    NJ Shore / Pine Barrens
    3,891
    That should be fine. I have done it many times. 7/8" is 22.2250 mm. Depending on wrench it may fit better than a cheap metric, I.e. Snap-on vs Walmart wrench.
    Husqvarna TE300i Fuel Injected 2-Stroke 2019
    Yamaha XT225 - 1999 Serow
    Yamaha TW200Z - 2010
    Yamaha BW200 Electric Start! - 1986
    Yamaha TTR225R - 2003
    Husqvarna 701 Enduro - 2017
    Kawasaki Prairie 650 - 2002
    Aug 2018
    San Diego, CA
    149
    Quote Originally Posted by JerseyJeeper View Post
    Thank you JerseyJeeper.
    JerseyJeeper likes this.
    Senior Member TW Newb's Avatar
    Dec 2018
    Los Angeles
    184
    Jersey is correct. I use them interchangeably at work all the time. I use snap-on mostly.
    The nut isn't very tight at 65 ft lbs, so even a cheap socket should be fine
    2001 TW
    Pleasanton, CA
    5,781
    6,999
    Pleasanton, CA
    5,781
    Hey Tony,
    I'm not familiar with those tools, how do you like them?
    Brian
    Jul 2012
    Wet-ern Washington
    1,415
    Brian,
    Those are Knipex, a German company. I have these pictured wrench pliers as well as their Cobra water pump pliers. They are simply the most amazing hand tools I've ever used. They are a "get what you pay for" tool, and they're price often reflects that.
    TW-Brian and elime like this.
    - Leisure Time Larry -
    6,999
    Brian -- they are pretty good and as Larry stated not cheap. If you look at the Home Depot website and search " Knipex pliers" you will see what they make and sell for. They are first rate tools.
    Their home website -- http://www.knipex-tools.com
    Their videos about their tools. http://knipex-tools.com/media-center/product-videos/
    I would not hesitate to use them on the axle if I needed to but I do prefer a socket and torque wrench. Obviously one can't use a torque wrench with these "plier-wrenchs". Tony
    TW-Brian and Darth like this.
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,130
    The 7/8 will work however it is always best to use six point wrenches and sockets on tight nuts. I hate using the 12 point variety on any nut or bolt that needs some torque applied because they are the ones that cause the round over. Harbor Freight has the 22 MM six point socket as a single piece for just a few dollars. Actually HF sells a decent set of metric sockets and wrenches pretty cheap and they are OK for the casual garage mechanic.
    1987 Yamaha BW350 Big Wheel
  1. Stuck Axle Bolts
    By Avi Kwame in forum Technical Help
    Last Post: 02-12-2014, 08:53 PM
  2. Hollow rear axle please..
    By rebar in forum General Discussion
    Last Post: 06-18-2013, 07:08 AM
  3. rear axle won't come out.
    By scott in forum Technical Help
    Last Post: 09-21-2012, 11:18 PM
  4. Reversed rear axle bolt.
    By Trikstr in forum Performance and Customization
    Last Post: 09-02-2012, 10:09 PM
  5. Rear axle bearings
    Last Post: 12-24-2011, 10:25 AM
