Is the OEM carb a Mikuni carb?
Results 1 to 7 of 7
    Germany, Werdau
    1,014
    Hello,
    I've seen today on the Yamaha website, that the TW200 2013 does have a 28mm Mikuni carb.
    -> http://www.yamaha-motor.com/sport/pr...0/0/specs.aspx <-
    I always though, that the carb is from Teikei.
    Here's the part number for the carb: 5FY-14301-10-00
    This carb is also used on the bikes from 2001 to 2013.
    Can someone send a picture with the newer carb?
    What's written on it?
    Regards, Sebastian
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    On my 2009 it's a Teikei.
    Germany, Werdau
    1,014
    Thank you for the info.
    So, I think now, that Teikei is a brand name from Mikuni.
    Jun 2011
    SW, Ohio
    2,518
    Could be a sub company Mac?.....also,I've read where the threads on the Mikuni jets are different than the Teikei jets?.....I've never personally verified this however.
    Germany, Werdau
    1,014
    The Teikei and Mikuni mainjets are not the same, but 2 different Mikuni mainjets (mj) will fit into the Teikei carb.
    I think, that I've seen a long time ago (here in the forum) that the Mikuni and the Teikei mj numbers are nearly the same, but not exactly the same.
    N100604
    8,0mm - head diameter
    M5 x 0,75 - thread
    9,0mm - complete length
    5,0mm - thread length
    N102221
    6,0mm - head diameter
    M5 x 0,75 - thread
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    Desert, SoCal
    7,369
    Teikei are their own outfit. No public relationship with Mikuni. Apparently they do enjoy some sort of joint relationship with Yamaha for the production of carburetors in China:
    http://www.teikei.co.jp/e-index.html
  1. 1991 carb help
    By Snake2715 in forum Technical Help
    Last Post: 03-01-2014, 08:07 AM
  2. Searching for a Mikuni TM28-1 pumper carb overseas
    By PalmStateCrawler in forum Performance and Customization
    Last Post: 06-24-2013, 03:19 PM
  3. Mikuni TM28 Carb kit & Oem tk *SOLD*
    By PalmStateCrawler in forum TW200 Classifieds
    Last Post: 04-25-2013, 09:49 PM
  4. Mikuni 30 MM ebay carb
    By Stromper in forum Performance and Customization
    Last Post: 11-08-2011, 01:16 PM
  5. Newer CV carb vs. older carb. MPG
    By number356 in forum Technical Help
    Last Post: 03-28-2011, 11:25 AM
5fy-14301-10-00
mikuni
tk carb jet vs mikuni
tw 200 cv vs tk carburetor
tw200 forum mikuni carb
tw200 mikuni
whatbrandofcarbison2013yamahatw200
whatcarbison2013tw200teikeiormikuni
whatisbettercarbteikeiormikuniintw200
yahmaha - teikei vs mikuni carbs
yamaha tw200 mikuni carb
yamaha tw200 oem carb
