Capacity with oil cooler
Results 1 to 10 of 10
Like Tree13Likes
  • 1 Post By TW-Brian
  • 2 Post By TW Newb
  • 1 Post By SportsterDoc
  • 2 Post By Darth
  • 3 Post By christddel
  • 1 Post By GaryL
  • 3 Post By PlacerLode
Thread: Capacity with oil cooler
    Senior Member TW Newb's Avatar
    Dec 2018
    Los Angeles
    176
    Do you guys who run an oil cooler increase capacity? Or do you just fill to the factory line?
    2001 TW
    Pleasanton, CA
    5,635
    When I measured the volume of the oil held in my oil lines and cooler it was less than I expected, probably less than 1/2 of a shot glass. Just keep your resting oil level near the upper mark on the sight glass and you'll be fine.
    Dec 2018
    Los Angeles
    176
    Thanks Brian!
    Also there was no o-ring at the oil drain bolt on the filter cover, but it wasn't leaking. Are people ommitting this seal?
    2001 TW
    Dec 2018
    Los Angeles
    176
    Also a lil surprised by the metal. I read some is normal especially at break in but this is almost 3k miles and decent sized pieces.
    2001 TW
    Jan 2017
    Southern Nevada
    1,065
    Quote Originally Posted by TW Newb View Post
    That is more than I would expect. I got maybe 1/4 that amount at 249 miles and 14 days service for my first change.
    The second change was about 750 miles, two weeks later.
    Don't recall any on that oil change.
    How many miles since your last oil last change?
    How well was it drained?
    Smitty Blackstone likes this.
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Senior Member RaZed1's Avatar
    Oct 2015
    252
    As said, the lines and cooler only hold an ounce or two of oil, not enough to significantly affect oil level. Just keep oil to the full line and you're good. I always just dump 1 full quart in at oil changes and it usually comes out pretty much perfect, just shy of the upper hash mark.
    That's a little more crud in the filter than I'd expect. The top end of the engine is done bedding in by 5-600 miles, but transmissions can take a couple thousand to fully seat it. Keep an eye on it at oil changes, but unless it has other symptoms of a problem I wouldn't worry about it. These bikes use an engine dating to the early 80's, and manufacturing tolerances seem to still be from the early 80's also (cause of the common weeping base gasket issue, gas tanks and side panels not lining up well, chain adjusters being 1-2 notches off side to side, ect).
    Senior Member Darth's Avatar
    Nov 2013
    Timbercreek Canyon, Texas
    1,602
    A good "rule of thumb" for oil levels...
    Checking when cool/cold:
    Level should be at or a little above bottom line.
    Checking when warm/hot:
    Level should be at or a little below upper line.
    Whether oil is hot or cold, or a little low or a little high, level should always be visible in sight glass.
    Level should be checked with bike in vertical attitude. With bike leaned over on side-stand, sight glass level will always read a little low.
    Cardinal Rule: Feel good about your bike and Have Fun!
    Pick one:
    Mel and Rhodetrip like this.
    Still, I rise!
    Humans: simultaneously capable of such genius and such douchebaggery!
    "Give a Damn"
    - C. M. Howe, Jr.
    Senior Member christddel's Avatar
    Oct 2010
    Belgium
    375
    Hello,
    The oil level I put just to the Max level.
    After a day without the engine running, the oil circuit is empty.
    At the 1st start, it takes 1 minute for the oil circuit to fill, that the oil reaches the cylinder head.
    Do not run the engine above 2.000 rpm for 2 minutes.
    My oil cooler is this one...
    PlacerLode, Rhodetrip and Darth like this.
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    7,919
    How much oil the cooler and lines consume depends upon the size of the cooler and lines. I have my own opinions about these coolers and their benefits. Our TWs are designed to run hot and be air cooled. I think out in a desert setting while running slow in extreme heat they will be good however here in the north east where the temp rarely gets above 90 and averages somewhere closer to 60 there is no need nor benefit from the cooler. When I had a cooler on my bike here it took considerably longer for my engine to warm up to full operating temp where the bike runs best. Cooler is of course better but not TOO Cool.
    Rhodetrip likes this.
    1987 Yamaha BW350 Big Wheel
    Apr 2012
    Out West
    2,999
    Quote Originally Posted by christddel View Post
    Hello,
    cool nerf bars !!!
    Rhodetrip, Mel and Darth like this.
    "It's Like Warm Apple Pie"
  1. Lizardbreath oil cooler capacity??
    By LoneRanger in forum Performance and Customization
    Last Post: 06-16-2018, 06:30 AM
  2. WTB - Oil Cooler looking for an Oil Cooler Kit
    By Skin Walker in forum TW200 Classifieds
    Last Post: 01-01-2016, 05:15 PM
  3. Oil Cooler capacity?
    By Grant in forum Technical Help
    Last Post: 06-24-2013, 03:11 PM
  4. Oil Capacity Question?
    By Swamp in forum Technical Help
    Last Post: 06-06-2013, 01:02 PM
  5. oil cooler and engine oil capacity
    By AFISHALBIZ in forum Technical Help
    Last Post: 07-22-2012, 09:08 PM
