First I made a stick, then a board, and now a starter
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Like Tree84Likes
Thread: First I made a stick, then a board, and now a starter
    Pleasanton, CA
    5,635
    then I made a board,
    and now I've made a starter.
    I wore out my native right knee from years of kicking over old dirt bikes (and playing soccer, and running marathons!) and had it replaced a couple of years ago. Since then I have passed up some good craigslist deals because they were kick only bikes and so I wanted to see if I could come up with some kind of a non leg-powered motorcycle starter. I went online to get some ideas of what others had built for starting motorcycles. I kept some of the good ideas, threw out most of the rest and here is what I built.
    Over the past several months, I have picked up a (real) gas MIG welder, a chop saw, a small mill, some steel and began the development and fabrication process. I wanted something as mechanically and electrically simple as possible, portable, and easy to store. Also, since I am just a beginner garage machinist and welder, the design needed to be something that I could hack out and stick together mostly by myself. Here are some the basic components and fabrication steps that I started with.
    Attachment 188348
    I then bought a heavy duty starter for a big block Chevy motor and began sourcing the drive sprockets and chain.
    Attachment 188350
    Some more fab work and a mock-up of the assembly.
    After welding (and a lot of welding cleanup!).
    Time for initial assembly and functional testing.
    Everything is working, so time to take it apart again, paint and then re-assemble it again. Here is the finshed product, ready to use.
    Here is how it works. Roll the back wheel of the bike onto the rollers. With the bike in second or third gear, pull the clutch in and hold the bike in place with the front brake. Depress the footswitch to get the rear wheel spinning, then let the clutch out until the engine begin to turn over and (hopefully!) fires. Release the footswitch, pull the clutch in and roll the bike off the rollers.
    I learned a lot during this build, mostly by all of the mistakes that I made, but am pretty happy with the way it turned out.
    GOF
    GOF is offline
    Senior Member GOF's Avatar
    Dec 2018
    Buffalo, NY
    210
    I've seen the board. Gonna steal that idea.
    I get the starter. I'll keep that in mind for the future.
    But just what is the stick for?
    jtomelliott49 likes this.
    1988 Suzuki Savage
    1987 Yamaha TW200
    18,420
    And with the wheels you can tow it behind your next bike to restart it when out and about.
    What, no AGM? You remove, or tip the wet cell battery upright when storing that handsome bump-start cart?
    Nicely done Brian, I was impressed with your fabrication skills when I saw it under construction.
    EDIT: Stick is a portable motorcycle stand to carry on the TW. Lifts either the front tire or the rear depending where stick is positioned.
    Pleasanton, CA
    5,635
    Quote Originally Posted by GOF View Post
    A trail jack. You can read about it here. https://www.tw200forum.com/forum/tec...ade-stick.html
    Jun 2016
    New Rochelle, New York
    1,711
    I've seen those at the racetracks many times. Especially the vintage racers with decompression valves. No such thing as a magic-button.
    Some are homemade some look store bought (not sure what "store")?
    You did an incredibly beautiful job on that one. Really Top-Class.
    1995 BMW K75 (Elec Start)
    Pleasanton, CA
    5,635
    Thanks Fred!
    I was hoping that I could just use a jumpstarter, but they don't seem to work without an actual semi-functional battery in parallel. I also was hoping that I could use one of those plug-in battery charger/engine starters but they don't have enough current to do it. So I went with the wet cell battery. Is there a problem with laying the sealed wet cell battery on its side?
    Brian
    Pleasanton, CA
    5,635
    Quote Originally Posted by stagewex View Post
    Thanks Stagewex!
    I have seen a few places that are selling ones in the $8-9 hundred dollar range and up. I was mainly looking for project to practice my fabrication and welding skills, but I just couldn't excited about building a welding cart.
    Member Vektor's Avatar
    Dec 2018
    Newcastle, Ontario
    52
    I have to admit, I am impressed.
    Husqvarna 6440 - she may be old, but she still runs like a sewing machine.
    2006 TW200
    GOF
    GOF is offline
    Dec 2018
    Buffalo, NY
    210
    You do impressive work my friend.
    1988 Suzuki Savage
    1987 Yamaha TW200
    Senior Member Joemama's Avatar
    Apr 2012
    Lake County, Ca.
    1,238
    Very nice Brian, it turned out just as you had discribed at your last wrench and ride.
  1. Eat your heart out MrBracket, I made a stick!
    By TW-Brian in forum Technical Help
    Last Post: 09-30-2018, 03:33 PM
  2. Replies: 10
    Last Post: 09-02-2016, 05:59 AM
  3. Then and now.
    By ZDR1 in forum Off-Topic
    Last Post: 10-26-2015, 05:20 PM
  4. Now and then. Where did your TDub start and what has it become.
    Last Post: 09-25-2013, 07:07 AM
