Stock Exhaust. Is it supposed to be that loud?
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Like Tree75Likes
Thread: Stock Exhaust. Is it supposed to be that loud?
    Junior Member JacobK's Avatar
    Jul 2016
    Ireland
    15
    I'm not the first owner of this bike but the exhaust is stock. Trying to figure out if they are supposed to be this loud or if I have a problem. I don't mind a little noise but prefer as quiet as possible. I even wear ear plugs while riding but the noise level still bothers me. I've changed both gaskets on the exhaust but am still wondering if there might be a leak. I'm considering the home made second muffler add on. I've tried and failed to remove the screw holding the muffler end cap on - drill bit broken off inside bolt, may attempt again so i can try exhaust packing. I downloaded a free decibel reading app and according to what is stamped on the muffler it is correct. (Somewhere in the 80s i think)
    Any suggestions or advice? My header pipe could use a new paint job so i may be taking it apart soon anyway.
    Ken and jtomelliott49 like this.
    18,424
    Here are some possibly helpful threads from the past:
    Muffler repack?.
    Quiet muffler options?..
    A common solution here that works a bit is a 3/4 copper elbow affixed to your exhaust outlet, either 45 or 90 degrees directing exhaust downwards. I tried a 1" 45 elbow once that helped at a distance but in my opinion seemed louder to me while in the saddle.
    Jun 2017
    Milwaukee, WI
    1,208
    Watch some of the videos on YouTube with good sound quality. There are even some videos with before and after comparisons. Should be fairly obvious if yours is not stock. I would prefer them a bit quieter, but when you hear the DGs and FMFs the stockers don’t seem that bad. I like my neighbors a lot or I would have already experimented with aftermarket.
    PlacerLode and jtomelliott49 like this.
    01 street 203/204
    96 hybrid Shinko 241/428
    89 restored SOLD
    Jul 2016
    Ireland
    15
    Looks like my best bet is to try and take the muffler apart and repack it. I've read quite a few of the quieter exhaust threads while trying to solve this but i will keep looking. I will begin shopping for packing material and maybe a new gasket again for the muffler/header connection.
    jtomelliott49 likes this.
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    7,920
    Some guys open the muffler and remove the baffle and spark arrestor from it. If this is the issue you might need to buy a good used muffler. You might also try to find another local TW that is stock and listen to compare the sound to yours.
    1987 Yamaha BW350 Big Wheel
    Jul 2016
    Ireland
    15
    This is what i first thought had happened so I pushed a wire into the muffler and could feel the spark arrestor still attached. I don't think it has been tampered with but will still try and take it off to find out. There are not very many tw200s in Ireland although there are a few available for sale on line as of lately. I think the only ones here were imported by individuals. I see Tw125s every once in a while but not very often. Shipping to Ireland is also pretty expensive which makes buying large items on Ebay kinda pointless. Even shipping from UK or mainland Europe is a rip off sometimes.
    Mar 2017
    Yuba City, CA
    376
    If you take a look at this thread (from another forum): Z1's super duper stock exhaust mod...illustrated | Upgrade Projects | XT225+250 Rider's Group , you'll see how some people have modified their stock mufflers.
    If you pull the end cap off, the spark arrestor will come out with it. Then look in to the back of the muffler with a flashlight, and you'll be able to see if the baffle has been drilled out, or has holes punched in it.
    If this mod has been done, there is no way to repair it... but there are a few things you can do to mitigate the annoying droning noise it makes.
    Someone had already punched holes in my baffle, so I drilled it the rest of the way out, just to see if it made any difference. It did not.
    However, I got some fiberglass muffler packing, and wrapped it around the spark arrestor, and that calmed the noise down quite a bit!
    My muffler also had the tail-pipe stub cut off, so I welded a new one on, a bit longer and curved downward behind the rider, and that helped even more.
    It's still louder than stock, but much less irritating to the rider.
    Even if your baffle has not been drilled, I think you'll notice a nice improvement if you wrap the spark arrestor, and extend/angle the tailpipe downward.
    Good luck!
    Fred, Tweaker, PlacerLode and 1 others like this.
    Hailey, ID
    3,275
    See: https://www.tw200forum.com/forum/per...muffler-4.html
    Post #39
    And: https://www.tw200forum.com/forum/tec...t-muffler.html
    When I did the 2018, I used three 1/4 inch wide strips of masking tape to compress the fiberglass instead of wire....the theory being it would burn up after a while and the fiberglass would expand a little. Since I haven't yet replaced the fiberglass I don't know for sure that worked, but I do know for sure if you use too much or too wide tape the effect is not as good. In Ireland I would not worry much about being too rich, but it could happen.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Jun 2017
    Milwaukee, WI
    1,208
    The muffler endcaps are notoriously hard to remove. Or maybe it’s just me. I’m 0 for 3 on my bikes.
    01 street 203/204
    89 restored SOLD
    Jun 2013
    Forestburgh, NY
    7,920
    Quote Originally Posted by Badgerflorida View Post
    Send the muffler to Admiral, he has just the right hammer for the job!
  1. Which direction is the oil element supposed to go?
    By Eric in forum Technical Help
    Last Post: 05-20-2015, 05:37 PM
  2. Replies: 6
    Last Post: 05-11-2015, 12:12 PM
  3. Please God tell me there is supposed to be............
    By Dryden-Tdub in forum Technical Help
    Last Post: 05-03-2015, 06:06 AM
  4. Is DG exhaust louder than stock exhaust without spark arrester
    By Little General in forum General Discussion
    Last Post: 08-19-2014, 06:08 PM
  5. Loud clunk when down shifting
    By moneal in forum Technical Help
    Last Post: 06-28-2011, 12:04 AM
