NON TW related mechanical question?
Results 1 to 10 of 20
Like Tree36Likes
Thread: NON TW related mechanical question?
    Apr 2014
    Dryden NY
    6,343
    Here goes. I have a Sno-Tech snowblower that simply would not start on Sunday even though it was running well on Saturday. After a good 25 minutes of trying to start the darn thing I over heated the starter and had fuel dripping from the exhaust. Lets get the simple things out of the way first. Fuel delivery was good. Spark was VERY good. Here is where I am confused........... Somewhere in my memory bank I remember someone decades ago telling me to try and cover the exhaust while starting. I did this and the snowblower sprang to life. It also ran like a top for three hours straight! Next morning same thing. I fired the starter for a few short bursts then covered the exhaust and boom fired right up. Once it has been running for a few minutes I can pull start it easily.
    What is the problem?
    Tom
    Badgerflorida likes this.
    Jun 2017
    Milwaukee, WI
    1,324
    I’ve never had experience with this but I remember reading that it causes enough unburned fuel to accumulate in the combustion chamber. Kinda like it is getting too much air and not enough fuel and covering the exhaust brings it closer to equilibrium. Sorta the opposite of choke? Definitely gonna try that the next time I’m scratching my head with a carb engine that won’t start.
    Dryden-Tdub and Fred like this.
    01 SOLD
    96 SOLD
    89 restored SOLD
    89 (restoration in process)
    05 (restoration in process)
    03 SOLD
    04 in great condition
    Senior Member ssgtrillium's Avatar
    May 2014
    Wellington County Ontario
    614
    Sounds like it may have flooded.Do you shut off the fuel when your done with it? When I start mine I pump the primer 5 or 6 times some fuel will leak out the overflow give it full throttle and choke then one very hard pull.Starts every time.
    Maybe your exhaust valve has too much carbon on it and is not seating all the way.
    Senior Member Darth's Avatar
    Nov 2013
    Timbercreek Canyon, Texas
    1,852
    Tom -
    Check Post No. 7 here:
    https://www.thetruckersreport.com/tr...starts.188959/
    And Badger's post, above.
    Looks like 2 different theories leading to the same result!
    This was all I could find.
    My recommendation would be to blow-off snow work, build a fire, pop some corn and crack a bottle of fine Bourbon.
    Play some games.
    Or put on some porn...
    Badgerflorida and Dryden-Tdub like this.
    "Faster, faster, faster, until the thrill of speed overcomes the fear of death."
    - Hunter S. Thompson
    Still, I rise!
    "Give a Damn"
    - C. M. Howe, Jr.
    7,012
    I have never heard of this trick but I do have a power washer that is a bitch to start so I will try this trick the next time I use it.
    Dryden-Tdub and Badgerflorida like this.
    Apr 2014
    Dryden NY
    6,343
    Quote Originally Posted by Darth View Post
    Tom -
    Play some games.
    I found this exact thread prior to posting this! Too funny. I always try to figure this stuff out prior to asking others but that was the ONLY thread I found on these symptoms. Thank you.
    Tom
    Darth and Badgerflorida like this.
    Apr 2014
    Dryden NY
    6,343
    Quote Originally Posted by ssgtrillium View Post
    I am not good about shutting off the fuel for a simple overnight rest. Long term storage however I do shut it off and run the bowl dry.
    Could this have something to do with the way the motor is set up? It claimed to have some function that made it easier to start in extreme cold temperatures? Not real specific on how they went about accomplishing this goal....... Thank you for your reply!
    Tom
    Mar 2011
    NJ Shore / Pine Barrens
    3,914
    It's the modulator valve..
    Purple likes this.
    Husqvarna TE300i Fuel Injected 2-Stroke 2019
    Yamaha XT225 - 1999 Serow
    Yamaha TW200Z - 2010
    Yamaha BW200 Electric Start! - 1986
    Yamaha TTR225R - 2003
    Husqvarna 701 Enduro - 2017
    Kawasaki Prairie 650 - 2002
    Mar 2011
    3,914
    Blocking the exhaust causes some gasoline to build up in the cylinder (for a richer mixture) .
    SECONDLY I've read (but haven't thought through the concept) that if you cover the exhaust tightly it keeps some of the compression in the cylinder from escaping so on the next compression stroke you have a little more compression and a little richer mixture. This equals an easier start usually. Especially if your choke is not functioning correctly. So they say...
    Lots of snow blowers have "auto-chokes" that stick and don't work (choke) fully on cold start. I've seen this at least three times.
    Warm engines need less choke, i.e., a less rich mixture to start.
    My guess is by holding the exhaust your keeping fuel from blowing out of the chamber for a richer mix, just like a properly working chike should do. Check your choke operation.. would be step one I think.
    Nov 2013
    1,852
    I'm happy to report that I have never actually even seen a snow blower in person...thank God!
    However, I did buy a snow shovel on sale a few years ago and have used it twice.
    Next time it snows enough to matter, I'll just tell Betty that it won't start...something to do with the choke. Or something.
    Still, I rise!
    "Give a Damn"
    - C. M. Howe, Jr.
  1. Auto CAD Mechanical 2017
    By Skin Walker in forum Performance and Customization
    Last Post: 11-21-2016, 09:38 PM
  2. What mechanical skills should every TW owner have?
    By JasonTX in forum General Discussion
    Last Post: 01-10-2016, 05:31 PM
  3. Another Carb Question (Choke related)
    By rystjohn in forum Technical Help
    Last Post: 02-21-2015, 07:41 AM
  4. Replies: 17
    Last Post: 02-08-2015, 08:07 PM
  5. TW related trinkets (where to get them?)
    By littletommy in forum General Discussion
    Last Post: 05-11-2013, 10:07 AM
