Kickstart question
Results 1 to 10 of 13
Like Tree33Likes
Thread: Kickstart question
    Senior Member Tiny-Wheel-200's Avatar
    May 2013
    Wasilla, Alaska
    692
    Kickstart question
    Hey I have a 2007 bike and an older engine with kickstart. I want to swap tge right case and kickstart from the old engine onto the 2007 engine. Has anyone done this and id love to hear what anyone has to say about this and any thing I should be aware of vefore I embark. Thanks in advance
    jtomelliott49 likes this.
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,468
    I want to do the same with my 15.
    Sep 2012
    Wichita, KS
    1,857
    There was once a member on here who did quite a few of these alterations back when the kick start kit was still available. IIRC you don't have to have an older pre 2000 sidecover, he would drill out the hole in the sidecover and put a new seal in there. Someone will chime in who knows more about this. TWBrian has done this I think.
    Tom in Wichita
    78 Moto Guzzi SP1000
    87 Yamaha TW200
    99 Yamaha TW200
    May 2013
    Wasilla, Alaska
    692
    Quote Originally Posted by jtomelliott49 View Post
    Right I should clarify I dont have the kit I just have a complete engine from a 91 that has other issues so I want to use the right case and kickstart mated to tge 2007.
    Fred likes this.
    Pleasanton, CA
    5,635
    Quote Originally Posted by Tiny-Wheel-200 View Post
    This is how I did my first kickstarter installation and I feel this is the best possible way to do one. You get to disassemble a working kickstarter from the donor engine and then reassemble it in the recipient engine. Your 2007 engine side cover just has a plug in it that can be pushed out so you can use whichever side cover that you wish to use.
    The most difficult part will likely be removing the old gasket from the engine case and/or the side cover. Also, you must be careful removing the inner clutch basket so you don't break one of the mounting posts. This is best done using a clutch holding tool, or can also be done using an electric or air powered impact wrench.
    If you PM me with your email address, I can send you some instructions that I prepared for the removal of the kickstarter assembly.
    Brian
    Jun 2016
    New Rochelle, New York
    1,711
    TW-Brian is wise. He helped me along with my kickstarter with instructions and advice. I had the "kit" but you are actually in better shape, your '91 engine already has 98% of what you need.
    No drilling or swapping cases either. Already have the pop-out on your '07 case where a kickstarter SHOULD be.
    You'll need a new gasket like Brian said and the little plastic plug to cover the kickstart spline. Keep it clean. That's pretty much it
    I do a lot of ordering through Babbitts On-Line but Revzilla, Tucker-Rocky, Yamaha on-line or your dealer can get these parts easy. Mine came in 3-4 days. Good Luck.
    Gasket-Kicker-Kit.
    Gasket, really all you need if the rest of the Kick-Start mechanism is in working order.
    Attachment 188786
    Installed with the exception of the little plastic spline plug. The one on the '91 will probably break.
    Not to worry, they cost $3.49.
    Go kick-start your bike.
    1995 BMW K75 (Elec Start)
    Senior Member Donzo's Avatar
    Oct 2016
    NorCal
    725
    I did mine recently. TW B helped me also...he be Da Man.
    Here's a pic of the clutch wrench in action and the kit with wrench. Worth it.
    Oct 2016
    NorCal
    725
    And stiffer clutch springs in pic. Why not while open
    Jun 2016
    1,711
    That's a great picture Donzo.
    Yes, the Clutch-Basket holding tool. Not absolutely necessary but a good thing to have.
    A whopping $13 or $14 bucks.
    Holding mine for a friend who is installing the kit in his xt225.
  1. Kick start case on non-kickstart engine
    By Idaho04 in forum Performance and Customization
    Last Post: 07-17-2013, 06:46 AM
  2. Bending an aluminum kickstart... ?????
    By zardoz in forum Performance and Customization
    Last Post: 10-04-2012, 09:10 AM
  3. Clutch fixed, now Kickstart problems!
    By SCARE! in forum Technical Help
    Last Post: 08-30-2012, 04:23 PM
  4. kickstart and oil cooler installed
    By 6Z37RLC in forum Performance and Customization
    Last Post: 08-18-2012, 01:31 PM
  5. Broken kickstart retention clip wall
    By sakogu in forum Technical Help
    Last Post: 07-21-2012, 05:34 AM
