A second snowblower question
Results 1 to 10 of 15
Like Tree6Likes
Thread: A second snowblower question
    Senior Member Tiny-Wheel-200's Avatar
    May 2013
    Wasilla, Alaska
    744
    I have an 8 up Tecumseh snowblower that starts if its primed but dies as soon. As you stop priming it. Whats my issue?
    Member jonnyquest's Avatar
    LaBelle, FL
    53
    Maybe a crack in the priming bulb, just a guess.
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,305
    Will it keep running eventually once it warms up a bit or no?
    May 2013
    Wasilla, Alaska
    744
    Nope just dies. I should mention that I had just do e work to replace part of the fuel line for whatever thats worth.
    rbm
    rbm is offline
    Jan 2011
    4,305
    Sounds like crap in the carb, i'd drop the bowl and clean for starters.
    Wingnut likes this.
    Sep 2014
    Mamaroneck, NY
    2,196
    Crap in the carb. Plugged idle circuit, most likely.
    Tennessee
    1,301
    I could not figure out a weedeater carb here recently. Blew it out multiple times. Ended up taking it to the shop and it came back running, but still not sure why. Maybe the vent lines, wasn't the primer, but it kinda sounds like it's one of the two for you if you unless the carb is clogged up. Pretty simple to take apart and clean.
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,130
    The primer bulb injects fuel in to the carb or cylinder depending upon where it is in the supply line. Once the engine starts the fuel is delivered by way of suction on the intake side as the piston goes down. If it runs while you are manually pumping fuel with the primer bulb but won't stay running then you have a clog in a line or an air leak in the vacuum between the carb and fuel supply. Most carbs have a diaphragm in them and this would be my guess that it is either torn or disintegrated.
    1987 Yamaha BW350 Big Wheel
    Apr 2014
    993
    Sorry TinyWheel; I can't resist. I don't have a clue as to your snowblower not working right.
    But as to your question of............ "Whats my issue?"...............I think your new bride would be the better person to ask!!!
    Dryden-Tdub likes this.
    Senior Member NVcowboy's Avatar
    Jul 2018
    Spring Creek, NV
    591
    I had a Norwegian hockey coach when I was a kid. He would get mad and say "Yoor mudder iss a snow blower."
    Fred and grewen like this.
    If you have to shoot, shoot. Don't talk. - Tuco Juan Ramierez aka "The Rat"
    There's 2 kinds of people in this world, those with guns, and those who dig. You dig. - The Man with No Name
    2018 TW200 - LCpl. Rex T. Dubber
    2010 Savage S40 650
  1. Need a good snowblower.
    By qwerty in forum Off-Topic
    Last Post: 06-27-2015, 12:01 PM
  2. second change to my bike; fuel filter
    By layne in forum Performance and Customization
    Last Post: 07-05-2011, 06:20 PM
  3. Second gear starts
    By Hobopoet in forum Performance and Customization
    Last Post: 03-19-2011, 05:43 PM
  4. My bike second ride
    By Matojo in forum General Discussion
    Last Post: 12-27-2010, 01:52 AM
  5. Humour - Second Opinion
    By Petrus in forum Off-Topic
    Last Post: 08-05-2010, 10:56 AM
