Air Forks
Results 1 to 10 of 19
Like Tree26Likes
Thread: Air Forks
    Feb 2017
    Waretown NJ
    535
    Air Forks
    Has anyone make air fork caps for their TW?
    Back in the day we uses to fit a schrader valve to the fork cap of out vintage mx bikes (which were current dirt bikes at the time) to assist the too soft fork springs .
    If there's room I'd like to try it on my 87. The suspension is so poor on these bikes, I'd like to get an aftermarket shock and do something with the forks
    Ken likes this.
    87 TW
    Senior Member elBuro's Avatar
    May 2013
    Boise foothills, Idaho
    114
    Yep, I got some valves, had the caps drilled and tapped. Been running them for years, 10psi each leg. Also run 15W oil a bit higher than stock. Great feel.
    No front end dive during normal braking on the street with this setup.
    Ken, Fred, Darth and 2 others like this.
    May 2013
    114
    Badgerflorida likes this.
    May 2013
    114
    My DIY Air Fork Caps ...
    Quote Originally Posted by Maxpower View Post
    Here is my solution ... Done ten years ago ...
    Fred, CJ7Pilot, Peterb and 2 others like this.
    18,424
    Quote Originally Posted by elBuro View Post
    But don't forget the add says: "It may need to up or back the steering wheel because there is a possibility that it will interfere depending on the body SR400/500 TW which has TYPE-I (with air valve)."
    If Ido get that TW500 they're talking about I'll figure out some way to deal with the steering wheel.
    Ken and Badgerflorida like this.
    May 2013
    114
    Damn, I can't find a Japan TW500 anywhere!
    Senior Member Xracer's Avatar
    Lake Placid,Florida
    3,701
    If you want to get real fancy put a cross over tube from one cap to another. That way you have just one filler valve and equal pressure in both forks.
    May 2013
    114
    Had that on my 78 RD400 in the day LOL
    18,424
    If the mythical 500TW 's steering wheel is anything like Triumph's handlewheel then those Wetbike schraders might be too tall without handlewheel risers. HandleWheel2-1-1.jpg
    elBuro and Lyterx like this.
    May 2013
    114
    Quote Originally Posted by fred View Post
    if the mythical 500tw 's steering wheel is anything like triumph's handlewheel then those wetbike schraders might be too tall without handlewheel risers. HandleWheel2-1-1.jpg
    yikes!
  1. XT250 air box & air induction mods
    By SportsterDoc in forum Other Bikes
    Last Post: 10-16-2017, 06:50 PM
  2. Air valve on top of forks
    By Drifter in forum Technical Help
    Last Post: 09-05-2012, 10:59 PM
  3. Replies: 5
    Last Post: 05-03-2012, 11:23 AM
  4. Tire Pump; Air Pump; Air Compressor
    By retmotor in forum General Discussion
    Last Post: 12-29-2011, 06:17 PM
