Shift Shafft Seal Issues
Results 1 to 7 of 7
Like Tree13Likes
  • 1 Post By Fester
  • 3 Post By Rider21
  • 4 Post By CJ7Pilot
  • 2 Post By Purple
  • 1 Post By CJ7Pilot
  • 2 Post By assquatch20
Thread: Shift Shafft Seal Issues
    Junior Member Fester's Avatar
    Nov 2018
    25
    Hi everyone. I had a slight oil leak at the shift shaft seal when I bought my TW, so I replaced the seal. It slowed down the leak, but didn't stop it. I think the PO might have buggered up the cavity that the seal goes into. Do you suppose that I could install a new seal with a small amount of liquid gasket material in the cavity to help ensure a proper seal?
    Fred likes this.
    Senior Member Rider21's Avatar
    Aug 2015
    Reno, NV.
    432
    Yamabond #2, if it's still around, on the outside of the seal only, should help if that's the problem.. Hopefully the shift shaft isn't bent. Yamabond 2 is what seals the center case joint. Good stuff. Seals good and comes off easy.
    Beauty is as beauty does.
    If it works good, it's beautiful.
    Mar 2017
    Yuba City, CA
    403
    When I bought Tommy's bike, he had just replaced the shifter seal. It didn't stop the leak, so he sent a new seal along with the bike. I replaced the seal again, and it still leaked.
    Well, upon closer examination, the shift shaft seal wasn't leaking... that's just the lowest point of the case when the bike is on the side stand, so virtually any leak will drip off right there.
    Mine turned out to be the outboard bearing seal on the counter shaft. I had to remove the side cover to access it, but once I replaced it, there wasn't another drip!
    Good luck with yours... little leaks can be annoying!
    Nov 2018
    25
    Wow, thanks CJ7Pilot. I never considered that. I guess I might have to clean things up well and spray some powder to verify source of leak.... How, exactly, did you determine the source of your leak?
    Mar 2015
    Ynys Môn
    4,630
    The two oil seals on either end of the front sprocket shaft are well known for leaking, and given the forces involved, it’s not surprising. As they are only a few bucks each, it’s good practice to change them along with the front sprocket.
    When you are putting on the left hand outer crankcase, make sure you don’t trap the wiring from the stator – another well-known thing to happen, as the magnets pull the thing all over the place ….
    - Hidden Content
    Mar 2017
    Yuba City, CA
    403
    Quote Originally Posted by Fester View Post
    I wiped everything clean, and let it sit over night. In the morning, I laid on the ground with a flashlight, and looked for the source of the leak.
    As I recall, the leak source was pretty evident.
    If this is the case for you, consider replacing your front sprocket, if it is worn. Maybe consider a different tooth count as well, depending upon your needs.
    There's lots of sprocket info on this forum (I like 15t front, 50t rear).
    You might as well kill two birds with one stone!
    Smitty Blackstone likes this.
    Tennessee
    1,301
    There's a thread here for sprocket replacement I think that mentions a very good practice, well two really. Put your sprocket cover bolts in a piece of cardboard, possibly using a gasket outline, to keep up with which is which. I've gotten to where I can tell which is which but it's good to do. Also, use a zip tie from the cover to the frame to keep your stator wires from getting frayed.
    Smitty Blackstone and Mel like this.
  1. Moose Racing Folding Shift Lever
    By TW Yamamoto in forum Performance and Customization
    Last Post: 12-27-2013, 03:15 AM
  2. M/C Boots and shift lever clearance
    By Old goat 11 in forum General Discussion
    Last Post: 04-01-2012, 09:47 PM
  3. Hot No SHift Fan?
    By Stromper in forum Performance and Customization
    Last Post: 03-17-2012, 01:57 PM
  4. shift problem
    By Thomas K in forum Technical Help
    Last Post: 01-07-2012, 04:30 PM
  5. Folding shift lever
    By 805gregg in forum General Discussion
    Last Post: 12-30-2010, 08:06 PM
