New TW, is this choke knob right?
Results 1 to 10 of 11
Like Tree5Likes
Thread: New TW, is this choke knob right?
    Junior Member Ray Hogan's Avatar
    Sep 2013
    4
    I just bought a new TW200. It’s a real pain to start. I’ve read everything I could find and the only thing I can figure is that the choke knob is not working properly...I hope, ha. It only pulls out about a quarter of an inch and will spring back if released. Is that right? Thanks for any help.
    Jun 2016
    New Rochelle, New York
    1,826
    Mine will pull out all the way and stay there but with the slightest touch will retreat like a frightened turtle to that halfway mark until warmed up. Couple minutes then I push it in all the way.
    So 3 positions I guess, out all the way/half way/in.
    1995 BMW K75 (Elec Start)
    Senior Member TW Newb's Avatar
    Dec 2018
    Los Angeles
    184
    Mine has 3 defined clicks. If you pull it really slow there's a 4th in there.
    Doesn't retract particularly fast. Gotta push on it.
    2001 TW
    7,011
    Open the idle mixture screw to 2 1/2 turns -- fine tune it later if you think it is necessary. All your problems will be solved.
    Tweaker likes this.
    Sep 2013
    4
    Real “technical” fix...just pulled on the choke knob a little harder, ha.
    Jul 2012
    Wet-ern Washington
    1,419
    It's not really a choke knob, but an enricher circuit plunger handle. In other words, it opens another passage for more gas to get in and doesn't close a traditional choke plate. Yes, it should pull out with at least 2 defined detents and stay out in the fully open position. All above advice is good and valid. Congrats, and good luck with the new bike.
    - Leisure Time Larry -
    19,166
    Unscrew the mechanism's plastic base from the carb aluminum body to see how it works if curious. Cute simple multi-stage detents should work and be self-explanatory when in your hand.
    Senior Member RaZed1's Avatar
    Oct 2015
    300
    There should be two defined detents, and it should stick at either one. There's a "half" and "full". With a slight poke, it should retract.
    It's just a little plastic circlip thing (integrated into the black plastic "nut" that screws into the carb and holds the plunger) that provides the detents to hold it out. I'm sure as it ages the plastic wears out and doesn't hold the detents as well, especially with ethanol fuel. It slowly attacks/degrades most plastics not specifically designed to be resistant to it, so it wouldn't surprise me after a decade or two the choke knob doesn't stay out any more.
    But yeah, opening the pilot screw to ~2.5 turns will make the bike much easier to start, and warm up much faster. In warmer weather you probably won't need the choke at all. It's hidden under a little anti-tamper plug on the bottom side of the carb. Drill a small hole in it, then pry the cover off. The adjustment screw is underneath.
    Senior Member Gulfrider's Avatar
    May 2014
    Florida Panhandle
    587
    While were on the choke question. Has anyone tried to add a choke cable and handle bar mount like other bikes. Loved it on my DR650.
    2005 TW200
    2007 Sportster 1200
    Senior Member grewen's Avatar
    Oct 2014
    Armstrong BC
    2,441
    Quote Originally Posted by Gulfrider View Post
    take alook on Procycle's site, they may have one. my xt225 had one
    Greg
    2020 yamaha TW200
    2019 honda cb500x
    2018 honda grom
  1. Replies: 48
    Last Post: 06-28-2016, 09:44 PM
  2. Why Choke/ no choke?
    By rastaman in forum Technical Help
    Last Post: 01-01-2015, 06:04 PM
  3. carb kit for 1991?? Choke won't choke!
    By manotickmike in forum Technical Help
    Last Post: 06-05-2013, 03:55 PM
  4. choke pull knob fell off
    By S0031 in forum Technical Help
    Last Post: 08-27-2011, 06:08 PM
  5. The knob
    By Petrus in forum Off-Topic
    Last Post: 11-10-2010, 11:30 AM
