Oil Leak
Results 1 to 10 of 18
Thread: Oil Leak
    Member ldw72120's Avatar
    Oct 2011
    Central Arkansas
    69
    I have an oil leak on the left side crankcase cover. I have replaced the gasket twice. I also replaced the shift shaft seal, the transmission shaft seal, and the outer transmission support bearing and seal, and it still leaks! I am unable to determine where the leak is coming from visually. And yes, my gasket surfaces were clean. Any ideas where to start?
    Ephrata, WA
    1,125
    My tappet covers (valve covers) were leaking and it ran down the left side of my bike when on the side stand. It frustrated the heck out of me.
    Start with a clean and dry bike and throw on some baby powder onto the left side of the bike and up towards the cylinder head. The powder will stick to the oil and show you where the oil is coming from.
    1990 TW200
    Oct 2011
    Central Arkansas
    69
    Quote Originally Posted by Rainman View Post
    It is coming out of the lower crankcase. The problem is that when it is ridden, the oil spreads, so even if you could see all the points it could leak, you can't tell where its coming from.
    6,975
    Check the neutral light switch. It is down where all the seals you named are, about 2 o'clock from the drain plug, IIRC. The center post gets loose and it oozes oil.
    Senior Member evan's Avatar
    Aug 2011
    Woodland, California
    2,126
    I was thinking of suggesting putting some tracer dye in engine oil but not sure if that would stain oil level window.....
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Just a guess?.....the manual shows a particular sequence in which the case screws/bolts should be tightened and proper torque value.....is this a possibility?.
    6,975
    My second TW was leaking oil. I replaced gaskets and seals as you did and it leaked less but still leaked. I took it apart one more time and found oil on the neutral light switch. I changed it and it hasn't leaked a drop since.
    Here is a picture of what it looks like. Red arrows point to where it was leaking from. You might be able to inspect it if you lean the bike to the right and look up under the cover with a flashlight. It is worth a try.
    BTW, it cost about $30.
    Oct 2011
    Central Arkansas
    69
    Quote Originally Posted by Tony View Post
    Thanks, I forgot to mention that I replaced the sealing gasket on the neutral switch but this weekend I will crank it and let it run to see if the neutral switch is leaking.
    Oct 2011
    Central Arkansas
    69
    Quote Originally Posted by frog13 View Post
    I actually torqued the screws. This TW has been leaking for two years so I have done it by the book! My other TW never leaks. I really think it may be the neutral switch because I noticed when I put it back together, it didn't start leaking until the engine was warm.
    6,975
    Quote Originally Posted by ldw72120 View Post
    I really think it may be the neutral switch....................................
    I am just curious, was it the neutral switch?
  1. Oil Leak
    By Senior Dirt Dog in forum Technical Help
    Last Post: 08-03-2012, 09:48 PM
  2. oil leak from where
    By jerz006 in forum Technical Help
    Last Post: 07-07-2012, 06:00 PM
  3. Oil leak...
    By xdac in forum Technical Help
    Last Post: 10-27-2011, 12:32 PM
  4. Oil Leak
    By B-dub in forum Technical Help
    Last Post: 08-09-2011, 01:19 AM
  5. Oil Leak
    By Mike Mecredy in forum Technical Help
    Last Post: 07-19-2011, 06:15 PM
neutral safety switch
tw200 oil leak valve cover
tw200 yamaha valve cover leak
