Switch mount
Results 1 to 2 of 2
Thread: Switch mount
    Junior Member Toyzgame's Avatar
    Aug 2018
    24
    Switch mount
    I am in the process of putting some bling on my TW. I would like a waterproof USB port and at least 2 toggle switches. Unless I find a simple way, I am going to try and 3D print a mounting box that will go under the indicator light box. 30mm x 43mm x 54mm. Maybe just the box for switches and a waterproof USB screwed to the right side of the box. What is everyone else using for their auxiliary switches?
    18,424
    I use very simple handlebar mounted rocker switches color coded for use.. MrGizmo bike has 4, two per side. However there is a whole world of combination deluxe handlebar switch clusters that may solve your goals. Things like a pair of these, but better.
    5V/4.2A Dual USB Charger Socket Waterproof Motorcycle Handlebar Clamp voltmeter Thermometer with on/off switch for Phones/Tablets/GPS
    Some do quite a multitude of tasks, might even be one that holds your toothbrush. Peruse the listings on e-bay or Amazon and you might find a combination cluster, or series of swiches
    Otherwise the custom under-binnacle box sounds great.
  1. Mirror mount and headlight switch questions
    By Lefecious in forum Technical Help
    Last Post: 04-16-2018, 04:13 PM
  2. Key ignition switch to Toggle switch - Anyone do this?
    By Skin Walker in forum Performance and Customization
    Last Post: 04-13-2017, 08:56 PM
  3. Very Customized Camera Mount TW200 for sale
    By SantaFeTW200 in forum TW200 Classifieds
    Last Post: 02-01-2011, 11:16 PM
  4. I lost the gas tank mount hardware!
    By brownie2 in forum Technical Help
    Last Post: 11-04-2010, 05:33 PM
  5. Kill Switch, Kickstand Switch, Clutch Switch
    By twmonae in forum Technical Help
    Last Post: 08-16-2010, 06:50 AM
