Sticky clutch question? - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Like Tree7Likes
Thread: Sticky clutch question?
  1. #11
    Jun 2015
    Nova Scotia
    1,244
    Me too....I mean yeah my 2015 has always been sticky when first started. Not every time but since I bought it it happens often. I believe the clutch plates get hot enough from the previous day for the oil to run off and when the bike sits cold the plates stick. It seems to me if you take longer in neutral to warm it and squeeze the clutch and roll the bike forward and back it can free the clutch plates.....Or maybe it was rolling forward and back in neutralwith engine running without squeezing the clutch...either way i sometimes break it free before it surprises me by taking off when I switch into 1st while still holding the clutch...lol
  2. #12
    Member wildhorse1966's Avatar
    Jun 2014
    72
    all 3 of the bikes we bought are like this 2 are 2019's and one a new 2017
  3. #13
    18,126
    'tis normal. Just make sure clutch lever adjustment was not inadvertently set improperly during dealer assembly from the shipping crate. Clutch should be disengaged when lever is almost fully depressed. Adjustment is done with thumbwheel hidden under rubber cover at clutch lever.
  5. #14
    Senior Member Tuber's Avatar
    Sep 2012
    VT
    730
    ​since its a wet clutch, I'm thinking it has to do with cold oil, esp in winter weather
    2005 Tdub
  6. #15
    Junior Member sierrastalker's Avatar
    Jan 2019
    Santa Cruz, CA
    16
    I've also got a new 2019, does the same thing. I've got somewhere between 200-250 miles on it. Like others, if I let it warm up especially on half choke and give the clutch a couple of squeezes to encourage the plates to un-stick then it shifts into 1st smoothly......but it has surprised me a few times lurching into a stall!
  7. #16
    Senior Member rurlndum's Avatar
    Jun 2013
    461
    A few revs with the clutch lever pulled in before you put in gear seems to work for me.
  8. #17
    Apr 2012
    Out West
    2,961
    all 100% normal on any wet multi disc motorcycle clutch
    this week I was starting Yamaha BW's that had not run for years and I have fun shifting into gear for the first time I rev the motor up and dump the clutch hoping to go for a pro stock motorcycle type launch but it's usually disappointing in that slightly higher RPM's when releasing the cold clutch lessens the "lurch" to pretty much zero
    I have had a BW200 where the clutch stayed stuck for the first 10 minutes of riding but once soaked with oil it all freed up and worked as new again
    Willys714 likes this.
    "It's Like Warm Apple Pie"
  9. #18
    Junior Member TWBigBlake's Avatar
    Apr 2019
    29
    Now that I’ve got some miles on my TW, I’m still having this problem... short of opening up any covers, thoroughly lubed the cable, lubed up the top of the push lever assembly, lubed clutch lever hinge area, changed out factory oil and filter, filled with yamalube 10w-40. It’s a 2019 and it’s not bad when it’s riding cold, after 10-15min of riding is when it starts getting noticeable, the longer I’m riding it gets more sticky, like immediate stall or come off the line super hard, kind of sticky....
    Thoughts? Help! Lol
  10. #19
    Senior Member RaZed1's Avatar
    Oct 2015
    218
    Quote Originally Posted by TWBigBlake View Post
    Thoughts? Help! Lol
    A bit of a lurch on the first shift of the day isn't anything to worry about, but if it gets worse as you ride and is stalling the motor I'd be hauling it back to the dealer. That's not normal. Usually shifting gets smoother/easier as the oil warms up.
  1. Is a sticky cold clutch just part of TW life or is there a fix
    By DougDotyTW200 in forum Technical Help
    Last Post: 05-29-2018, 04:57 PM
  2. Sticky clutch on brand new bike?
    By Fast Eddie B in forum Technical Help
    Last Post: 05-14-2017, 06:30 PM
  3. Sticky 3rd Gear?
    By nfpgasmask in forum Technical Help
    Last Post: 03-19-2013, 04:40 PM
  4. sticky rear brake
    By danwray in forum Technical Help
    Last Post: 03-01-2013, 08:32 AM
  5. My Sticky entry
    By goldenhtr in forum Performance and Customization
    Last Post: 08-05-2011, 01:23 PM
