Replacing steering head bearings!
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Senior Member evan's Avatar
    Aug 2011
    Woodland, California
    2,126
    Rode the black widow to my shop to remove front wheel and send it to local motorcycle shop for replacement of front tire/tube from old stock tire to Shinko sr244 that seems to be a favorite on this forum. Noticed steering felt funny and sure enough has a notchy type feeling when turn either way from straight ahead. Found Rainman's write up with pics (thanks Rainman!) in Tech section so I'll be doing that and replacing stiff fuel petcock. Spring is right around the corner so time to get the TW ready to ride!
    Ephrata, WA
    1,125
    Are you going to use new tapered roller bearing or just lube up your original ones?
    If you buy new roller bearings remember that the freezer is your friend when it comes to putting the bearing on the stem. Disassemble, clean everything, then stick stem in freezer while you remove old and install new races in the frame.
    1990 TW200
    Aug 2011
    2,126
    Thanks, going with new tapered roller bearing set.
    Ephrata, WA
    1,125
    Quote Originally Posted by importmech View Post
    Very nice. Take your time and have fun.
    1990 TW200
    Senior Member tw200sgp's Avatar
    Mar 2012
    Singapore
    258
    I put the tapered bearing set from procycle in.... it does make a positive difference.
    Mar 2011
    Gobles, michigan
    1,824
    If you go with the tapered bearings do you still need to freeze the stem ???????????? Thanks OMM.
    Ephrata, WA
    1,125
    Quote Originally Posted by omm View Post
    You don't have to. It just makes installation easier. I've done it both ways. When I did my Dad's TW, I didn't freeze the stem so I had to hammer on the bearing with many hammer strikes. No big deal, it just took some force. When I did my TW, I froze the stem and three or four solid whacks and the hammer and the bearings was on. The stem was only in the freezer for maybe 30 minutes, but longer is better.
    1990 TW200
    Senior Member Xracer's Avatar
    Lake Placid,Florida
    3,771
    Stem in the freeze and the races on a hot plate. They pretty much just fall into place. Also make sure you reroute your cables the correct way. Takeing things back apart is a pain.
    Aug 2011
    2,126
    freezer and hot plate good advice. Decided to put handle bar risers on while I'm at it. I'm 6'2" and hunching over while standing is a pain. What everything think? 2 inch risers?
    Junior Member respond2us's Avatar
    Jan 2013
    29
    I ordered new steering head bearings literally a year ago, just hadn't gotten "a round tuit". But just read Rainman's how-to and figure I need to quit putting it off. My steering is pretty horrible. I figured out how bad it was since my wife has an '87 TW with beautiful steering. She won't even ride mine. haha... So, here I go. Wish me luck.
  1. All Balls Steering Bearings Question
    Last Post: 08-31-2015, 10:08 PM
  2. What quality of bearings
    By christddel in forum Technical Help
    Last Post: 09-09-2012, 04:28 AM
  3. Steering Head Bearings
    By Rainman in forum Technical Write-Ups
    Last Post: 04-28-2012, 07:54 PM
  4. greasing the steering bearings
    By cdsdave in forum Technical Help
    Last Post: 04-07-2012, 01:37 PM
  5. Fork Bearings?
    By retro in forum Technical Help
    Last Post: 10-10-2010, 02:48 AM
tw200 steering head bearings
