quick question
Results 1 to 4 of 4
Like Tree7Likes
  • 5 Post By methamphetasaur
  • 2 Post By GaryL
Thread: quick question
    Junior Member gosiris420's Avatar
    Mar 2017
    Miami, Florida
    6
    quick question
    What is the purpose of that wire next to the the clutch wire that goes into the left handle (the clutch)....mines came off but doesn't seen to affect anything so far, think it might of came off when i installed my new risers...anybody?
    Senior Member methamphetasaur's Avatar
    Jun 2015
    Conifer, CO
    1,152
    Safety circuit on ignition system.
    If the bike is in gear, it won't start unless the clutch is disengaged. With that wire broken [circuit open] the bike will no longer start in gear even if you disengage the clutch.
    I'm guessing you've only tried starting it while in neutral, which is why you haven't noticed anything different.
    Since Yamaha uses an either/or setup- you'll be fine. Suzukis on the other hand require both to start.
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    7,919
    Probably part # 21 here. https://www.partzilla.com/catalog/ya...e-switch-lever
    Good to have if you ever stall out on a steep incline and need to fire it up while in gear.
    Sthrnromr and Badgerflorida like this.
    1987 Yamaha BW350 Big Wheel
    18,420
    The purpose of the electrical wire next to the clutch cable that goes into the clutch lever's perch is as described, another starter circuit safety interlock.. If indeed though the OP is talking about a second electrical wire it possibly is for a heated grip, not likely in Florida though. All good though, just adding a little less confusing terminology.
  1. Quick Yamaha dealer question
    By MCC1776 in forum General Discussion
    Last Post: 07-15-2013, 07:16 AM
  2. Need some help quick! Oring question?
    By bogey72 in forum Technical Help
    Last Post: 05-20-2013, 07:42 AM
  3. first oil change, quick question
    By russ5415 in forum Technical Help
    Last Post: 02-13-2013, 10:25 PM
  4. Help quick air filter question
    By mtngirl in forum Technical Help
    Last Post: 08-21-2012, 12:48 PM
  5. Quick base gasket question
    By Larry in forum Technical Help
    Last Post: 07-22-2012, 09:11 PM
