Blinkers Not Working
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Like Tree56Likes
Thread: Blinkers Not Working
    Junior Member Olympus's Avatar
    Feb 2019
    20
    Guys I bought my first TW last night. Itís a super clean 2000 model with 2200 miles. It has a dead battery, so I bought a new one and itís on the charger now. But when I kick start the bike, all the lights work except for the blinkers. Headlight works hi and low, dash lights work, tail light works, brake light works, and the two front blinkers light up solid orange. But the back two blinkers donít blink at all and the front two come on solid, but donít blink.
    I feel like it has to be something simple since the bike is so dang clean. But I canít seem to figure it out.
    jtomelliott49 likes this.
    Jun 2016
    New Rochelle, New York
    1,711
    Flasher or dirty contacts. That's pretty simple. Did they work when you picked up the bike?
    1995 BMW K75 (Elec Start)
    Feb 2019
    20
    No, I just picked it up yesterday. Didnít work then either and I just thought it was because the battery was dead.
    Is there supposed to be a clicking sound when you turn the blinker switch one, like in a vehicle? Because there is not.
    Jun 2017
    Milwaukee, WI
    1,208
    I would test the flasher relay for continuity with a multimeter. Part #42 here
    https://www.partzilla.com/catalog/ya...m/electrical-1
    PlacerLode and jtomelliott49 like this.
    01 street 203/204
    96 hybrid Shinko 241/428
    89 restored SOLD
    Feb 2019
    20
    Is there supposed to be a clicking sound when the blinker is on like in a vehicle?
    Jun 2017
    Milwaukee, WI
    1,208
    On my older bikes it seems more audible, but yes you should be able to hear it clicking without the engine running.
    01 street 203/204
    89 restored SOLD
    Feb 2019
    20
    Ok, then thatís my problem Iím betting. I here no sounds. Iím guessing itís the relay. Do you know where I can find the relay on the bike?
    And can someone tell me if itís normal for the front signal lights to both be on solid when the bike is running?
    Jun 2016
    1,711
    Yes, the front lights should be on similar to a running light all the time. If you don't like that you can disconnect them. So your lights (at least your front one's) do at least work.
    Feb 2019
    20
    Yes, the front 2 lights come on solid and stay on. The back blinkers just donít come on. And the blinker indicator on the dash does not come on. Thatís what has me thinking it must be the blinker relay.
    Frosty Hollow
    12,909
    Quote Originally Posted by Olympus View Post
    Ok, then that’s my problem I’m betting. I here no sounds. I’m guessing it’s the relay. Do you know where I can find the relay on the bike?
    And can someone tell me if it’s normal for the front signal lights to both be on solid when the bike is running?
    On both my 2005 and 2015 TW's the flasher relay was on the right side kind of hidden around the frame just above the exhaust.
    I believe all but the 1987 models, the "running lights" (blinkers), are on steady when it's running.
  1. Blinkers not blinking
    By Adrock101 in forum Technical Help
    Last Post: 05-20-2018, 11:55 PM
  2. Replies: 5
    Last Post: 01-01-2016, 12:15 PM
  3. blinkers not working
    By thndrin in forum Technical Help
    Last Post: 04-02-2013, 07:33 PM
  4. starter not working
    By newbiker in forum Technical Help
    Last Post: 09-01-2012, 05:34 PM
  5. Electric start not working? Test this!
    By stinkycheezmonky in forum Technical Help
    Last Post: 11-20-2010, 12:37 PM
