Oil filter cover O ring size?
Results 1 to 5 of 5
Like Tree3Likes
  • 2 Post By elime
  • 1 Post By Donzo
Thread: Oil filter cover O ring size?
    Senior Member Cerberus's Avatar
    Aug 2018
    San Diego, CA
    123
    I just replaced all the O rings but my metric O ring kit did not have the largest one, the oil filter cover one. Could anybody provide the size of that O ring? Thank you for your time.
    6,933
    I use 2-227 N-70. They are a little teeny bit to big but can be pushed into the groove and work well plus I have a local source where I can get them for something like 25 cents each.
    O-rings through the dealer is robbery! The first and last o-ring I bought from the dealer cost me $9 plus tax and I think it was one for the oil filter cover.
    If you have a Grainger close by take the cover to them and they can get one to fit exactly right. I hear they are very good.
    Donzo and Fred like this.
    Senior Member Donzo's Avatar
    Oct 2016
    NorCal
    725
    I took my O ring to Reibes Auto parts and they have a large box of rings - found a perfect fit and bought 5 for like 2 bucks.. At my local store the box is behind the parts counter.
    Fred likes this.
    Aug 2018
    San Diego, CA
    123
    Thank you both gentlemen.
    Junior Member sopheiatay's Avatar
    Mar 2019
    6
    Thanks gentleman !!
  1. Oil drain o'ring size
    By Lyterx in forum Technical Help
    Last Post: 06-09-2015, 10:41 PM
  2. Oil filter cover- long bolt broke- repair options?
    By jpscott1 in forum Technical Help
    Last Post: 02-03-2013, 03:44 PM
  3. Oil Filter Cover O-Rings
    Last Post: 09-19-2012, 05:38 AM
  4. Oil filter cover leaking
    By junk munk in forum General Discussion
    Last Post: 10-25-2011, 12:15 AM
  5. oil filter cover leak
    Last Post: 10-16-2011, 06:55 PM
