FYI - Minor clutch slippage on this full synthetic
Results 1 to 10 of 16
Like Tree24Likes
Thread: FYI - Minor clutch slippage on this full synthetic
    Oct 2018
    Rural, South Carolina
    630
    Just a FYI - I used this oil rather than my goto Shell Rotella to try out on the TW. It says designed for wet clutches. I had some slippage at higher rpm/speeds today on my ride. I will be draining and replacing, just FYI. I'll either go back to Shell Rotella or just drop in some OEM Yamalube. Keep in mind you results may vary. Just a heads up and something to keep in mind when shopping for oil. Disclosure: I have had good luck with this oil in the distant past and figured I would try it again. The TW specifically however doesn't seem to like it too much. My experience anyhow.
    DISREGARD: READ POST #11 --> https://www.tw200forum.com/forum/tec...tml#post988998
    Last edited by Sthrnromr; 03-04-2019 at 09:06 AM. Reason: Updated for accuracy and DISREGARD link with explanation
    2010 TW200 - The Goat
    Triumphs
    ATVs
    18,407
    Here, let me spend some of your money:
    78-17 Yamaha TW200 Barnett Friction Clutch Plate kit -5 Plates (Fits: Yamaha TW200)
    Vesrah Heavy Duty Clutch Spring Set SK-206
    Seriously, nice heads up r.e. the Lucas Motorcycle oil; I would have tried it if I saw it on the shelves.
    The clutch upgrades have gotten good reviews by members here. However you would have to scrape off the old clutch cover gasket, something I wouldn't wish on anyone. Just the stronger springs, or fifty cents for 4 washers under OEM springs might increase engagement forces enough to compensate for the slippery Lucas.
    jtomelliott49 likes this.
    Oct 2018
    630
    I put in a new clutch with stiffer springs when I installed my kickstart. Great info and links though. Would have saved me some time when I was looking. Thanks. Also weird to me how watery the Lucas was. Very thin it seemed
    Fred and jtomelliott49 like this.
    Triumphs
    ATVs
    Hailey, ID
    3,265
    I've never had any slippage in either TW with Mobil 1 4T racing 10w40 after break-in. In total 16,000 miles.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Senior Member Darth's Avatar
    Nov 2013
    Timbercreek Canyon, Texas
    1,601
    Make sure you have enough slack in the cable take-up. If it is too tight it can induce slippage.
    (Slight gap between clutch lever and perch, handlebar end.)
    Sthrnromr and jtomelliott49 like this.
    Still, I rise!
    Humans: simultaneously capable of such genius and such douchebaggery!
    "Give a Damn"
    - C. M. Howe, Jr.
    Oct 2018
    630
    Quote Originally Posted by Darth View Post
    Thanks. Will double check tomorrow.
    Triumphs
    ATVs
    Member TW-JMS's Avatar
    Jun 2018
    Oromocto, New Brunswick, Canada
    57
    I have been running this very oil in my '14 TW since the initial oil change. After 2000+ km, no issues so far... knock on wood!
    2014 TW. UBIQUE!
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,841
    I have always used a little Lucas Heavy Duty Oil Stabilizer for slipping clutches. I ran Valvoline 20/50 not for wet clutches oil and many months or years later it slipped so I added the oil stabilizer which made the clutches grab. No more than about 4 ounces and don't go over on the oil level. At 40,000 miles I did finally change the clutch plates out to Barnetts. The steel clutch plates were still in great shape.
    Also, if it grabs too good you may have loosen your clutch adjustment a tad.
    Fred, Sthrnromr and jtomelliott49 like this.
    Senior Member Ski Pro 3's Avatar
    May 2014
    El Dorado, California
    789
    Why did you decide to try something other than the Rotella?
    I use Rotella and haven't noticed any problems at all. Good, solid shifting, engine temps, suspension of contaminants.
    The bear slayer!
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    7,911
    I will be more interested in hearing if the change back or to some other oil corrects the issue. Seems to me once the discs take a glaze or begin slipping there is little you can do other than to replace the discs or sometimes you can deglaze them with fine sandpaper or soaking them in some chemical. I tend to doubt the issue is caused by the oil but rather the change made the already present issue more pronounced. Keep us posted on what you find.
    1987 Yamaha BW350 Big Wheel
  1. Replies: 20
    Last Post: 04-28-2017, 08:37 AM
  2. Replies: 15
    Last Post: 02-04-2015, 06:40 PM
  3. 2010 TW clutch slippage!!!!!
    By biker44 in forum Technical Help
    Last Post: 10-10-2014, 10:07 AM
  4. nu bee with clutch slippage problem~help!
    By paelo man in forum Technical Help
    Last Post: 09-23-2013, 08:03 AM
  5. clutch slippage
    By TheRedRider in forum Performance and Customization
    Last Post: 06-06-2013, 11:05 PM
