Clutch Install
Results 1 to 8 of 8
Like Tree16Likes
  • 2 Post By SHAG
  • 3 Post By TW-Brian
  • 1 Post By Xaman
  • 1 Post By Sthrnromr
  • 4 Post By Xaman
  • 2 Post By Sthrnromr
Thread: Clutch Install
    Senior Member Xaman's Avatar
    Mar 2012
    168
    Clutch Install
    Hey guys. Put my kickstarter kit on yesterday, and it works however, I now have no clutch, lol. Basically no pressure on the clutch lever.
    I just tried to reinstall the opposite of tear down of the clutch. But looking today at the installation instructions I see reference to a “ball” next to the pushrod. I don’t recall seeing a ball!
    I didn’t pay any attention to adjusting the clutch, so tomorrow morning I’m taking it apart again, planning to adjust the clutch per service manual.
    But after reading the service manual I’m nervous about not seeing a ball. Any thoughts?
    2013 model if that matters.
    Senior Member SHAG's Avatar
    Oct 2013
    Bradford, Pa
    969
    You may have dropped the ball
    joeband and Miaugi like this.
    2013 TW200 - 8k- miles
    2018 X-MAX - 6k- miles
    Pleasanton, CA
    5,740
    Yes, there is a small ball bearing that goes between the adjustment screw in the center of the clutch holding plate and the clutch actuation rod that runs through the center of the main drive shaft of the transmission. It is possible that when you removed the clutch holding plate this ball bearing came out and rolled away without you noticing it. Without this ball in place, the symptoms that you describe will result.
    Badgerflorida, Miaugi and Fred like this.
    Mar 2012
    168
    Bummer. New intel though, after watching a video, I realize I never pulled the clutch actuation rod, only the adjustment screw (which I thought was the rod, but was only about 2” long). I did all this on the side stand, therefore leaning up slightly. is it possible that the bearing stayed put while I removed everything? If so, is it possible to have the symptoms of no clutch pressure on the lever just from a failure to adjust the adjustment screw?
    basically I’m trying to decide if I should go back in tomorrow, or wait a week until I get a bearing ordered...
    thanks for the help fellas. I’m a learning, and lessons like this are sticky.
    Sthrnromr likes this.
    Oct 2018
    Rural, South Carolina
    670
    If you never pulled that rod out the ball is still in there. However, I suspect your clutch is not adjusted or even close. When you adjust and turn the screw you’ll see the lever and tension move. Now, don’t over adjust and get the lever too tight, as your clutch will slip. Don’t ask me how I know. Tdubs like a little slop.
    Badgerflorida likes this.
    Offroad:
    TW200 - The Goat
    KTM 300 - Orange Dragon
    ATVs
    Onroad:
    Triumphs
    Way too many past bikes and builds to list. I won't bore you. Questions? Just ask.
    Pleasanton, CA
    5,740
    I have installed about a dozen kickers and have never touched that adjustment screw in the center of the clutch plate.
    So, if your clutch was working before installing the kicker, and you didn't touch that adjustment screw, then I'd say you must have dropped the ball.
    If you did remove, or adjust that screw, then it possible that the ball is still in place and you just failed to reset that adjustment screw.
    Either way, you've got to go back in there.
    Mar 2012
    168
    I definitely removed the adjuster screw (guess I didn’t have to, but I thought it was the push rod and the service manual said to remove it...).
    I went back in, and seems everything is good. I set the adjustment screw and now I have a working clutch. ... and a Kicker. Whew.
    Thanks all, she’s ready for a test ride tomorrow.
    Oct 2018
    670
    I did the same thing but I put in a new clutch and springs while I was in there and definitely removed the screw. Glad you got it sorted.
    Miaugi and Xaman like this.
    Offroad:
    TW200 - The Goat
    ATVs
    Onroad:
    Triumphs
  1. Clutch slip. BAD clutch slip!
    By Darth in forum Technical Help
    Last Post: 12-10-2018, 02:48 PM
  2. Clutch Engagement vs Free play in clutch lever
    By Jay-2 in forum Technical Help
    Last Post: 04-09-2014, 06:24 AM
  3. Borrego Rack install
    By Schleppy in forum Technical Help
    Last Post: 04-23-2011, 11:11 AM
  4. Rotopax install
    By triple3jrb in forum Performance and Customization
    Last Post: 02-24-2011, 11:01 AM
  5. Proper way to install a Blackout switch?
    By brownie2 in forum General Discussion
    Last Post: 11-17-2010, 09:47 PM
