Collar bushing part # 2
Results 1 to 8 of 8
Like Tree9Likes
  • 1 Post By TW-Brian
  • 2 Post By TW-Brian
  • 4 Post By Tw200quebec
  • 1 Post By Tw200quebec
Thread: Collar bushing part # 2
    Senior Member Tw200quebec's Avatar
    Oct 2016
    164
    What does part # 2 do exactly, its a part of the starter when you remove the left side cover, it a bushing called collar.
    Pleasanton, CA
    5,749
    I would guess that it helps keep the starter gear (Item # 1) from floating around on their common shaft (Item #3).
    Oct 2016
    164
    It's because I am getting a friend's TW ready for summer, changed the front sprocket, had to remove the left cover when I finished and was cleaning up I found a ring that looks just like part # 2 on the floor. not knowing what it was I decided to look in the parts diagram to try to see if it came from the bike. I did an oil changed and all, the motor starts and no weird sound what so ever... I am wondering, if the piece really came from inside the motor, without this ring bushing the motor would make a weird noise or maybe not even start. Should I take the cover back off and check...?
    Pleasanton, CA
    5,749
    If the part you found looks like either of the two silver (aluminum) parts in the pic below, then it is the part that should be mounted on the shaft above the smaller starter gear as shown below.
    I am going go out on a limb here and say that without this bushing installed, the smaller starter gear appears to be effectively constrained between the larger starter gear and the starter clutch housing that is mounted on the back side of the flywheel.
    Translation: Looks like your friend's bike will probably be okay without this bushing being installed.
    (p.s. how good of a friend is he ?)
    Oct 2016
    164
    Hello TW-Brian, It's exactly this part, it must have fell when I was working on the bike, I will take the cover back off and reinstall it. I what to keep a good friend a friend (PS thanks for the picture, better details then the parts diagram)
    Pleasanton, CA
    5,749
    If you just lay the bike over on its right side, you can remove the left side cover without draining the fresh oil.
    Darth likes this.
    Oct 2016
    164
    All done! I drain the oil in a clean pan and then poured in back in the engine, took about 20 minutes and I have a happy friend that will stay a friend. Thanks again!
    Sthrnromr likes this.
    Pleasanton, CA
    5,749
    Quote Originally Posted by Tw200quebec View Post
    You're welcome, glad I was able to help!
  1. Replies: 8
    Last Post: 01-30-2018, 03:57 PM
  2. Camshaft Collar - think this is going to be a problem?
    By Skin Walker in forum Technical Help
    Last Post: 04-03-2017, 08:25 PM
  3. Starter rebuild kit / bushing - 1989
    By Dusty_Bottoms in forum Technical Help
    Last Post: 10-15-2014, 11:53 AM
  4. Swing Arm Bushing question
    By Drifter in forum Technical Help
    Last Post: 03-18-2014, 11:59 AM
  5. Cam Collar Removal
    By ryderg in forum Technical Help
    Last Post: 05-18-2011, 09:49 AM
