What is this wire for??
Results 1 to 3 of 3
Like Tree5Likes
  • 3 Post By Peterb
  • 2 Post By stagewex
Thread: What is this wire for??
    Junior Member Nolealum's Avatar
    Jan 2019
    19
    Trying to bring a 1987 TW back to life. Not a mechanic but have learned a lot from the forum and YouTube!
    Bike has a hard time starting, will run a little bit once started and then hard time cranking again. Uncle is coming over Sunday to help so hopefully will help w carb, etc.
    Trying to work on electrical while I wait. This wire is hanging here and have no idea where it goes or what it is for. Have service manual but wiring diagram is Greek to me. Any help to what it is and where it plugs into would be great. Wires are blue w white stripe on one and yellow on other.
    Bought used speedo and indicator cluster and struggling w indicator lights but will save that for another day....
    Thanks in advance.
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,484
    That is from your side stand switch. There should be a female plug with the same color wires or it may be bypassed?
    Badgerflorida, GOF and Sthrnromr like this.
    Jun 2016
    New Rochelle, New York
    1,773
    Since it looks like that has not been used in awhile make sure you clean all the contacts before you re-connect. A dab of dielectric grease (on all you connections) ain't a bad idea either.
    Maybe the previous owner bypassed for a reason? Bad or dirty switch at the kickstand possibly.
    GOF and Peterb like this.
    1995 BMW K75 (Elec Start)
  1. WTB KM Speedo and wire, tail light, flashers.
    By Luc in forum TW200 Classifieds
    Last Post: 06-27-2012, 06:49 PM
  2. How to change the spark plug wire?
    By Sverige21 in forum Technical Help
    Last Post: 05-27-2011, 08:37 PM
  3. Spark plug wire change
    Last Post: 04-20-2011, 08:30 PM
  4. Where does this wire go?
    By tok-tokkie in forum Technical Help
    Last Post: 01-07-2011, 12:21 AM
  5. Wiring Question - Where does this wire go???.
    By Grant in forum Technical Help
    Last Post: 12-25-2010, 12:31 PM
