Head gaskets
Results 1 to 5 of 5
Thread: Head gaskets
    6,975
    When I was much younger, dumber and poorer, I didn't know you were not supposed to reuse head gaskets. I did on several different engines, from a Model A Ford, a flat head Ford V-8, multiple Briggs and Stratton engines, some 2 stroke outboards and probably others I have forgotten about, and never to my knowledge did it cause any problems.
    So......has anyone reused the head gasket on their TW? If so, did you experience any problems after doing it?
    Senior Member rm_hm's Avatar
    1,619
    I'll reuse an easy gasket to replace now and then but........ I'll spend the $10.00 for a new one first then to take a chance on the old base gasket leaking and having to tear the engine apart again.
    It's a 2-4 hour operation to replace the lil bugger.
    The dreaded base gasket leak on our bikes show that a subpar gasket will leak.
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Quote Originally Posted by Xxxx
    X
    Your much to gabby "X".
    Nov 2011
    norcal nutjob
    3,313
    maybe cat's got his tongue??
    Senior Member mattmus4357's Avatar
    Oct 2012
    NW Arkansas
    250
    Quote Originally Posted by Rich View Post
    I'm going to have to replace mine, not looking forward to it.
    I took a small engine class in high school and never could get the darn thing back together
  1. Carb gaskets and o-rings
    By azbusmo in forum Technical Help
    Last Post: 04-22-2013, 06:38 PM
  2. WTB TW Cylinder Head
    By ldw72120 in forum TW200 Classifieds
    Last Post: 10-31-2011, 06:55 AM
  3. cylinder head
    By christddel in forum Technical Help
    Last Post: 02-28-2011, 04:38 PM
  4. Cam Slop in Head
    By rhanson94 in forum Technical Help
    Last Post: 01-31-2011, 06:15 PM
  5. Head rebuild
    By whitewash in forum Technical Help
    Last Post: 08-04-2010, 07:58 PM
head gasket
tw200 head gasket leaking
xt225 base gasket
yamaha outboard can you reuse head gasket
