Dual Cable Throttle?
Results 1 to 5 of 5
    Member Avi Kwame's Avatar
    Nov 2012
    44
    I want to replace my grips, does the TW have single or dual cable throttle? I see two cables coming off it, but it also could be considered one wrapped around.
    These supposedly fit a 06 TW200, but the auction says " note the throttle tube only works with single throttle cable models, will not work with dual cable models."
    http://www.ebay.com/itm/HANDLE-BAR-T...-/280938413919
    Hailey, ID
    3,344
    Quote Originally Posted by Avi Kwame View Post
    It's a dual throttle cable, one cable when you twist the grip towards you, one when you twist away from you or let go...(which is controlled by the spring)
    This is so that if one cable jams or the spring breaks, you still have positive shut down control.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Nov 2012
    44
    That's what I thought, thanks. I wonder if I could just pull the grip off the tube...
    Aug 2011
    Cayce, SC
    3,109
    Just buy some new grips! Do you really need a new throttle tube? The easiest way I have found to remove grips is to use wd-40 and slid the straw under the grip and squirt. The grip will just twist right off and you can wipe off the throttle tube and install your new grips. I really like progrips. They are a little longer than normal so you will have to cut them or do what I do and add a piece of tube to the end of yours as such:
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Sep 2011
    Southcoast MAsshole
    2,661
    i agree with palmstatecrawler wd40 works...or compressed air (like you would use to clean a computer) or an air compressor with a tube fixture is less messy and you don't have to worry about wiping everything down and your new grips not staying on...you probably don't need a new throttle tube...i run pro grips as well...like palm said they are a little long but on my pars it didn't matter too much...as far as putting on new grips you can use a grip glue...i use aerosol hairspray and just let it dry in the sun
    skip to 50 seconds in
    http://www.ehow.com/video_4974611_re...and-grips.html
  1. positon of throttle cable pulley
    By Tyler in forum Technical Help
    Last Post: 05-16-2013, 08:49 PM
  2. carburator throttle linkage
    By HercJerk in forum Technical Help
    Last Post: 03-30-2013, 08:49 PM
  3. Throttle return spring
    By sailing502 in forum Technical Help
    Last Post: 01-20-2013, 07:47 PM
  4. missing throttle return cable
    By dubstep in forum General Discussion
    Last Post: 11-04-2012, 06:36 AM
  5. Throttle sticking
    By RingSteel in forum Technical Help
    Last Post: 02-29-2012, 01:20 PM
1989 yamaha tw200 throttle cable
how do you assemble throttle spring on tw 200
how to remove throttle cable from yamaha tw200
throttle cable adjustment tw200
throttle return spring yamaha tw200 schematic
tw throttle cable adjustment
tw200 removing throttle cables
tw200 throttle adjust
tw200 throttle cable adjustment forum
yamaha tw 200 throttle replacement
