Adjusting the Carb Float
Results 1 to 4 of 4
    Senior Member mattmus4357's Avatar
    Oct 2012
    NW Arkansas
    250
    Good afternoon guys, sorry for another question. Bike is running great after the tune-up I gave it. Leak is stopped for the most part after rebuilding the petcock and needle valve & assembly. However, now I need to adjust my float level to completely stop it. I know in the '01+ supplement on pg39 it says to "slightly bend the float tang." Exactly which one is the tang? The tab that it rests on or the two prongs that hold it in place? Which way do I bend it? Thanks
    Senior Member FortPayne's Avatar
    Nov 2011
    Alabama
    326
    There is a tab resting on the needle valve, that is what you bend. The wording is confusing if you've not done it before. Away from the valve to lower the level and vise versa.
    Tenaciously Deviant Unwittingly Brilliant
    Aug 2011
    Cayce, SC
    3,109
    When you look at it still attached to the carb you can see the piece that hits the top. This stops the floats from raising any higher and pushes the float valve up stopping gas flow. Bend it up so that it will allow hit the top earlier allowing less gas to "fill" the bowl.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Oct 2012
    NW Arkansas
    250
    Thanks guys! I'll work on that this evening.
  1. Problem removing float hinge pin ( older style carb )
    By Bucknutz in forum Technical Help
    Last Post: 04-15-2013, 05:25 PM
  2. Carb float needle valve seat question?
    By Twowheeler in forum Technical Help
    Last Post: 01-08-2013, 12:34 PM
  3. Carb Float Height?
    By tok-tokkie in forum Technical Help
    Last Post: 01-03-2013, 09:16 AM
  4. carb - needs adjusting (1998 model)
    By craigology in forum General Discussion
    Last Post: 11-29-2010, 10:36 AM
  5. Carb float bowl screws
    By jbfla in forum Technical Help
    Last Post: 10-05-2010, 02:57 PM
adjusting float level on a tw200 yamaha
mikuni tm28 carb float adjust
tw200 float height
