Possible to identify model year from engine serial #?
Results 1 to 5 of 5
Like Tree2Likes
  • 1 Post By supachip1
  • 1 Post By Bucknutz
Thread: Possible to identify model year from engine serial #?
    Senior Member Bucknutz's Avatar
    Apr 2012
    Lower Hudson River Valley of The Communist State of N.Y.
    487
    I bought a titled 89 Tw with two extra engines . Is it possible to determine what model year the engines are using the engine serial numbers? Thanks in advance for any assistance. Rubber side down. Dave
    18,858
    From the web:
    "You can call Yamaha customer service and they can decode your engine serial number and convert it to year and model type. Yamaha has been happy to help in this regard."
    I was also was directed to check off-road.com & Netbikes.com
    Apr 2012
    487
    Ok, thanks Fred. I will give it a try.
    Apr 2013
    385
    do you want to know exact or ball park?
    the auto timing chain adjuster is 01- present, will also have bigger inlet boot with pipe coming out of the top, and 2 grey, 1 white plug connections for the electrics.
    pre 01 will have manual adjuster and will not have the boot pipe. 1 white plug and red, brown, and possibly 1 black/white bullet connecters, (87 will also have 1 yellow..i think)
    if that helps any
    Fred likes this.
    Apr 2012
    487
    Thanks, I was looking to identify the specific year. They all were fitted with kickstarts, so I am reasonable assured they are generation one engines. They are also all black which tells me they are 87, 88, or 89. Thank you for your advice. Rubber side down, Dave
    Fred likes this.
  1. early model frame/ late model engine
    By beltaine in forum Performance and Customization
    Last Post: 02-07-2017, 11:42 AM
  2. Is this correct year/model? What model is it??
    By terobert in forum General Discussion
    Last Post: 05-27-2016, 04:55 AM
  3. Serial number question from Bangladesh
    By Gerry in forum General Discussion
    Last Post: 03-19-2012, 01:02 PM
  4. Serial Numbers
    By unded in forum Technical Help
    Last Post: 03-19-2012, 11:19 AM
  5. Identify your T-dub Model Year
    By TrailWhale in forum General Discussion
    Last Post: 08-09-2010, 05:59 PM
