1992 tw200 Jet sizes
Results 1 to 6 of 6
Like Tree5Likes
  • 3 Post By Leisure Time Larry
  • 1 Post By Darth
  • 1 Post By elime
Thread: 1992 tw200 Jet sizes
    Senior Member kennethshaw's Avatar
    Jan 2011
    170
    Hi. Back again after a couple years and buying a tw200 again. Couldn’t stay away I guess. Well I got around to taking the carb apart and the jets were pitted and nasty to a point where I couldn’t see what size the jets were. Can anyone tell me what the standard jet sizes are for this year’s carburetor? Also, is shimming the needle and larger mains also recommended? I’m running the same stock exhaust and air filter. Thanks!!
    Jul 2012
    Wet-ern Washington
    1,403
    - Leisure Time Larry -
    2004 TW200, 13-54 gearing, Shinko 241, Race Tech Emulators, Procycle front springs, Works Performance rear shock, Emgo handguards, Luckybike mirror risers, Ken Sean DS foldable mirrors, 30mm Tusk bar risers, Seat Concepts, Kick Starter kit, Plasti-dip camo coat, Cycle Pumps, Ricochet Skid Plate, flood and spot LED pod lights, Sena, Garmin etrex 20 GPS, IMS 313114folding shifter
    Senior Member Darth's Avatar
    Nov 2013
    Timbercreek Canyon, Texas
    1,602
    Look here, too.
    jbfla's most excellent carb photos...
    https://www.tw200forum.com/forum/tec...ification.html
    Sthrnromr likes this.
    Still, I rise!
    Humans: simultaneously capable of such genius and such douchebaggery!
    "Give a Damn"
    - C. M. Howe, Jr.
    6,933
    Start with new stock jets before experimenting. I bet that is all you will need. #114 main #40 pilot
    admiral likes this.
    Jan 2011
    170
    Got the bike running with the stock jets. Similar to my 1998 tw that I sold, the bike bogs just as I give it throttle. I still have some shims so I'm going to add 2 to the needle. My question is, do I need to up the #40 pilot jet? Also, at cold start up, I don't have to pull the choke. I assume this means it is running rich which means I would need to screw the idle jet in. It's at 2.5 turns out. Would appreciate any advice before I start buying things.
    Thanks!
    Hailey, ID
    3,275
    Since you can't tell exactly what the pilot jet is, replacing it with the stock #40 would be a cheap test if you didn't already do that. 2.5 turns out would be normal, but try 2 turns and see if it has any effect on the bogging. Depending on whether it's bogging because it is a bit lean or because it is a bit too rich, the two shims could make it worse or better. The shims start to have an effect right off idle, so don't try adjusting both the pilot needle or the shims at the same time. Obviously it's much simpler and faster to fiddle with the pilot needle, you can do it right on the side of the road between test runs. Don't burn yourself!!!!!
    I used 2 turns out on my 2010 at 5 to 6,000 feet, and one shim. On the 2018, no shims and 2 turns out. I can't tell any difference.
    I would also have a REALLY careful look at the air filter, the air box, and the snorkel with a very bright flashlight.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
  1. A photo of my new OEM Carb for a 1992 TW200.
    By farnorthdriver in forum Technical Help
    Last Post: 08-18-2016, 08:26 AM
  2. Jet sizes.......
    By oldmercman in forum Technical Help
    Last Post: 11-28-2015, 11:23 PM
  3. Source for alternet jet sizes?
    By jfelman in forum General Discussion
    Last Post: 07-18-2015, 02:47 PM
  4. 1992 TW200 6000 miles
    By jrt3046 in forum General Discussion
    Last Post: 05-06-2012, 06:31 AM
  5. 1992 TW200 $1150
    By Smokeslider in forum TW200 Classifieds
    Last Post: 02-21-2011, 03:11 PM
