2017 Jetting Recommendations
Results 1 to 10 of 11
Like Tree4Likes
Thread: 2017 Jetting Recommendations
    Junior Member fagro's Avatar
    Mar 2019
    19
    Just picked up a 2017, like new, 300 miles on her. She is very cold blooded.
    I drilled/removed plug for pilot mixture screw. 2-1/2 turns out it was better but not good.
    What jetting do you recommend for sea level to say 3000 ft, East coast.
    Dec 2017
    Western Washington
    215
    I live at sea level and ride to 3000 ft. Occasionally up to 7,500 ft. Iíve had very good results with a 130 main jet and a 34 pilot jet. Also two shims on the needle with 2 1/2 turns on mixture screw.
    Results may vary, but thatís what has worked for me for a 2002, 2009, 2012, and a 2016 tw.
    Best of luck, and welcome!
    1972 Yamaha DT 175, 1974 Kawasaki 125, 1976 Suzuki TM 250, 1979 Yamaha 750, 1977 Husquvarna 360, 1979 Husquvarna 250, (2) 1980 Suzuki RM 400ís, 1971 Husquvarna 400, 1983 Honda V65 Magna, 1987 Suzuki 230 Quad, 1987 TW200, 1990 TW200, 1996 Honda XR 650, 1998 Yamaha 300 King Quad, 2000 Harley Davidson Heritage, 2006 Kawasaki KLX 250s, 2007 Arctic Cat 650 Quad, 2010 Polaris Sportsman 850 Quad, 2006 Yamaha Grizzly 660 Quad, 2002 TW200, 1995 TW200, 2008 TW200, 2016 TW200.
    Mar 2019
    19
    Thank you.
    Went to start her today. Started... sputtered.... died. Would not restart. Could not get it restarted. Removed carb took apart. It was spotless. Cleaned jets and passages, reassembled. Tryed to start... nada.
    Pulled plug, dry. Dipped it in gas... put back in.
    Fired right up.
    Added Seafoam to tank, went for a ride. Seamed to run good.
    Time to hunt down those jets.
    Jul 2012
    Wet-ern Washington
    1,411
    I highly recommend OEM jets.
    Part #s here... https://www.tw200forum.com/forum/tec...et-part-s.html
    Copy paste in search at at place like www.partzilla.com
    - Leisure Time Larry -
    Dec 2017
    Western Washington
    215
    Larry is right on, OEM and Partzilla is the way to go.
    Junior Member 400nitro's Avatar
    Apr 2015
    27
    do those carb settings work on a 08. are the carbs the same?
    Tweaker likes this.
    Dec 2017
    Western Washington
    215
    Quote Originally Posted by 400nitro View Post
    Should be be the same for all carbs after 2001,
    Mar 2019
    19
    Quote Originally Posted by Gastone165 View Post
    I live at sea level and ride to 3000 ft. Occasionally up to 7,500 ft. I’ve had very good results with a 130 main jet and a 34 pilot jet. Also two shims on the needle with 2 1/2 turns on mixture screw.
    Results may vary, but that’s what has worked for me for a 2002, 2009, 2012, and a 2016 tw.
    What sort of gas mileage are you getting with this setup?
    Dec 2017
    Western Washington
    215
    The mileage is good, but I would imagine not quite as good as the smaller jets. I never really checked what it was before I changed them, and haven’t really paid much attention to what my current TW’s are getting for mileage right now. I do know they kick the crap out of my Harley.
    I’m sure someone can chime in on what they’re getting for mileage with the 130 main and 34 pilot jets.
    Feb 2018
    Western Pa.
    310
    I have the 130 main jet, a couple of shims on the needle and a couple of turns out on the mix screw. I get between 70 and 80 mpg on the road, but I'm running 15 tooth front and 47 rear with Bridgestone 203/204 tires. With the carb tuned the engine seems so much more comfortable. I don't have to wind out the engine as much - more power with partial throttle than before.
  1. Replies: 4
    Last Post: 01-11-2019, 02:04 PM
  2. Replies: 18
    Last Post: 08-04-2011, 07:56 PM
  3. I Need Some Recommendations
    By assquatch20 in forum General Discussion
    Last Post: 04-26-2011, 07:06 AM
  4. Recommendations for Modern Front Tire
    By zbigman in forum General Discussion
    Last Post: 02-26-2011, 07:00 PM
  5. Any recommendations for Flagstaff area?
    By the-wild-man in forum Trails, Off-road, and Adventure Riding
    Last Post: 10-01-2010, 03:18 PM
