Clutch replacement
Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By Sthrnromr
Thread: Clutch replacement
    Junior Member Studawg777's Avatar
    Mar 2019
    12
    Clutch replacement
    What's up everyone? I was just wondering if anyone out there in the T-dub world has replaced their clutch? Did you just do the friction rings? Or did you do the springs too? How bad was it? And how did you know it was time to replace it? I appreciate the input!
    Senior Member YamTW87's Avatar
    Mar 2017
    Greece
    123
    Hi!
    There are many threads about this subject. eg https://www.tw200forum.com/forum/tec...life-span.html
    Better replace with EBC or Barnett clucth disks and their stiffer springs respectively.
    2007 Suzuki V-Strom 650
    Oct 2018
    Rural, South Carolina
    630
    I replaced mine. Was it needed or necessary? Definitely not. Why did I do it? I was installing the kickstarter and had to remove the clutch as part of the process, so I just figured while everything was apart I would opt for Barnett discs and stiffer springs. To each his own.
    Miaugi likes this.
    2010 TW200 - The Goat
    Triumphs
    ATVs
    Mar 2019
    12
    Ok people, thanks for the help, sounds like the Barnett is the most popular. I'll have to do it to it! 👍
  1. Seal replacement during chain/sprocket replacement
    By TWROG in forum Technical Help
    Last Post: 02-03-2015, 11:42 AM
  2. Clutch replacement
    Last Post: 08-25-2014, 09:41 AM
  3. Clutch replacement
    Last Post: 08-07-2014, 08:57 AM
  4. Clutch replacement
    By Prime in forum Technical Help
    Last Post: 01-22-2014, 08:38 AM
  5. Replacement clutch recamendations, stock, EBC?
    By DBR0051 in forum Technical Help
    Last Post: 01-12-2011, 06:45 AM
