Throttle help
Results 1 to 9 of 9
Like Tree21Likes
  • 1 Post By SeanIsHungry
  • 1 Post By Badgerflorida
  • 2 Post By SeanIsHungry
  • 4 Post By Ski Pro 3
  • 6 Post By SeanIsHungry
  • 3 Post By Darth
  • 2 Post By Ken
  • 1 Post By Darth
Thread: Throttle help
    Junior Member SeanIsHungry's Avatar
    Nov 2018
    4
    New user here!!! PS I have my first Jimbo shield!!
    Anyway, I have a 2015 tw200; I removed carb to clean jets, but after reinstalling realized throttle won't return or snap back correctly. This is noticed by looking at the throttle assembly outside of the carb ie I made no adjustments to the throttle cables around the handlebar.
    NOTE: looking around forums I found a post by a bushwacker or some such name with similar issue, he posted back in January. However the difference between his post and mine is; when I removed my carb I left throttle assembly on. So I shouldn't have to adjust the spring
    , correct??? If memory serves me right, he removed the throttle assembly when he did his carb mods, however I left it on the carb, so I'm wondering if the advice for his post would even apply to me??
    I took a before pic( picture taken before carb was removed when throttle returned correctly) and can post that if need be. I'm going to try to lube the cable with 3-in-1 lube to see if that will help.
    Thanks!!
    Edit: I also did not touch the nut that is square in the middle of the assembly, I only adjusted the 10mm nuts that are on the cables, if that helps.
    jtomelliott49 likes this.
    Jun 2017
    Milwaukee, WI
    1,208
    Welcome to the forum!
    Does the throttle twist easily, or is there resistance? Pics might help. I recommend reading through this entire thread as it covers many possible solutions to a binding throttle, even though the OP has not found a resolution that I’m aware of. Cheers
    https://www.tw200forum.com/forum/tec...le-cables.html
    01 street 203/204
    96 hybrid Shinko 241/428
    89 restored SOLD
    Nov 2018
    4
    I actually have seen that thread before believe it or not, I was hoping there would have been a conclusion..
    at any rate, my bike only has 700 miles..
    I will take pictures tomorrow in the sunlight and update post tomorrow!
    Nov 2018
    4
    https://youtu.be/xnp991frDN8
    In the video the throttle is only returning to the default position when I manually turn the throttle handle back. So in the video when you see the throttle body going back to idle, that's only because I'm manually turning the throttle to closed position. Also I re applied lube J
    Here is the link to the video
    Darth and jtomelliott49 like this.
    Senior Member Ski Pro 3's Avatar
    May 2014
    El Dorado, California
    790
    Maybe it's at the throttle on the bars that is somehow jammed up? Try loosening the throttle holding screws and see if the throttle will snap back.
    Ken, Darth, jtomelliott49 and 1 others like this.
    The bear slayer!
    Nov 2018
    4
    Quote Originally Posted by Ski Pro 3 View Post
    I will try that now
    Edit: it worked!!!! I removed the handguards and kept making adjustments to the throttle grip while watching the assembly. I found a sweet spot where it snapped back perfectly, held tight and then screwed in screws as hard and tight as possible to retain integrity!
    Thanks
    Tweaker, Ken, Ski Pro 3 and 3 others like this.
    Senior Member Darth's Avatar
    Nov 2013
    Timbercreek Canyon, Texas
    1,602
    Sean, on most materials that turn, spin, slide or otherwise rub on something else, a light spritz of Silicone spray will keep 'em slick & happy!
    It doesn't catch and trap dirt like oily/greasy stuff does. Lasts a long time.
    Aerosol KY...sort of.
    Ken, jtomelliott49 and Fred like this.
    Still, I rise!
    Humans: simultaneously capable of such genius and such douchebaggery!
    "Give a Damn"
    - C. M. Howe, Jr.
    Ken
    Ken is online now
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,847
    Quote Originally Posted by Darth View Post
    I have used white lithium grease under the throttle tube and it sure makes the throttle spin easy.
    Nov 2013
    1,602
    Quote Originally Posted by Ken View Post
    Ken, I think for that application the white lithium grease would be better than silicone spray.
    I've used it in the past with great results.
    The advantage of silicone spray for many applications is it's quick, easy and gets in all the nooks & crannies.
    I think I'll go now and grease my throttle tube...
    Still, I rise!
    "Give a Damn"
    - C. M. Howe, Jr.
  1. Throttle response help
    By jdnphotography in forum Technical Help
    Last Post: 01-24-2018, 04:42 PM
  2. New owner - throttle response help ....
    By cvillanu in forum Technical Help
    Last Post: 05-17-2017, 02:12 PM
  3. Bad throttle response, won't go past 50% throttle video
    By trcooperone in forum Technical Help
    Last Post: 05-10-2016, 04:46 PM
  4. Throttle cam help
    By Allucaneat in forum Technical Help
    Last Post: 03-07-2016, 08:56 AM
  5. Help....Throttle Cables
    By EWB in forum Technical Help
    Last Post: 11-16-2015, 07:16 PM
