Fork spring upgrade
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Like Tree72Likes
Thread: Fork spring upgrade
    Member TWBigBlake's Avatar
    Apr 2019
    Tacoma, WA
    82
    Fork spring upgrade
    I’ve ordered some stiffer front springs to accommodate my excessive downward gravitational disposition, and while I am no stranger to mechanical work, most of my motorcycle work has been limited to wiring, assisted engine work and basic maintenance...
    So before I get waist deep in replacing the fork springs, is there anything the experienced folks on the forum might recommend to save me time and headaches?
    I.E. special tools, laying parts out, stuff to have before hand, what order to do stuff in, etc.
    GOF and PlacerLode like this.
    Pleasanton, CA
    5,634
    Hi Blake,
    Check the "Similar Threads" listed below, and here is thread showing what is inside the forks so you know what to expect.
    https://www.tw200forum.com/forum/tec...mystified.html
    Good luck!
    Brian
    Senior Member Miaugi's Avatar
    Oct 2017
    Alfred, On
    463
    This would be a good place to start. Typically no special tools required but to fully disassemble the fork tubes you do have to make a special removal tool which basically is a 2' threaded rod with two 3/4" nuts locked on one end. If I've got this wrong someone will correct my memory and better describe it to you.
    Darth likes this.
    6,932
    Check the fork oil level first. If it is low the front end is very soft. Bring it up to about 130 mm and you might be satisfied with it and it is a lot cheaper than buying new springs.
    It worked for me. My TW used to bottom out all the time and now it bottoms very seldom. Hardly ever. It worth a try.
    TW-Brian, grewen and PlacerLode like this.
    Apr 2019
    Tacoma, WA
    82
    Hi Blake,
    Good luck!
    Brian
    Thanks, I tried searching “front forks” and missed this one. Definitely makes it seem a lot less intimidating.
    TW-Brian and PlacerLode like this.
    GOF
    GOF is offline
    Senior Member GOF's Avatar
    Dec 2018
    Buffalo, NY
    210
    Servicing the front forks is on my todo list. Thanks for bringing it up.
    1988 Suzuki Savage
    1987 Yamaha TW200
    Senior Member nihil's Avatar
    Jan 2018
    278
    I just did the springs and emulators on my forks last weekend. If you're only doing springs it should be quick and easy. If you're doing anything with the lower section, you can improvise a tool for it with the nuts/bolts as mentioned, or Napa/Evercraft have a 19mm hex head socket that almost works. It's a bit too large to fit in the tube, so I turned it down a few mm on the lathe and fits nicely. I took pics of the guts with everything lined up as it goes if you're interested.
    I also did the rear spring (both front and rear were the highest rate available from Procycle as I too am not of a petite disposition, ~250'ish at 6'2"). It feels like an actual motorcycle now instead of riding a wheeled waterbed.
    Might also be good to do fork boots as a preventative measure if they have some age to them. Beyond that, keep everything clean and you should be good to go.
    admiral, Darth and PlacerLode like this.
    `09 TW200
    Oct 2018
    Rural, South Carolina
    630
    Quote Originally Posted by nihil View Post
    Slight hijack...on the rear spring what method/tool did you use to compress the spring for removal?
    PlacerLode likes this.
    2010 TW200 - The Goat
    Triumphs
    ATVs
    Jan 2018
    278
    Quote Originally Posted by Sthrnromr View Post
    I wouldn't recommend doing it the way I did it. When/if I have to do it again, I'll buy or fabricate some properly sized spring compressors or try the floor jack and strap method.
    That being said, I used one of the two pronged hook type spring compressors made for car size springs (this style), made sure at least one hook on each end of each compressor had a good bite, covered it with a folded up moving blanket to help keep things from flying, and puckered/winced my way to a successful spring swap after having it pop loose a couple times.
    Just for emphasis, this is not a good way to do it, risks life and limb, you'll shoot your eye out, etc...
    admiral, TW-Brian, Darth and 4 others like this.
    `09 TW200
    Frosty Hollow
    12,909
    Where there's a will there's a way. This is how I do it. It's not the safest technique but if you take your time and be careful it works. The hardest part was getting the straps just right so the shock would remain upright and not flop over. With everything (spring) strapped down you don't really have to worry about projectiles just the shock flopping over rather quickly.
  1. Pro Cycle fork springs and rear shock spring
    By sandhillrider in forum TW200 Classifieds
    Last Post: 08-21-2018, 08:33 PM
  2. Fork Spring question
    By Ken in forum Technical Help
    Last Post: 01-10-2017, 06:53 PM
  3. Replies: 2
    Last Post: 06-06-2014, 08:18 PM
  4. Pro Cycle F/R spring upgrade for 210lbs help
    By ilbiker in forum Technical Help
    Last Post: 04-23-2014, 07:01 PM
  5. Banshee shock spring upgrade!
    By Tiny-Wheel-200 in forum Performance and Customization
    Last Post: 03-07-2014, 09:38 PM
