Rear brake wear indicator
Results 1 to 8 of 8
Like Tree2Likes
  • 1 Post By Purple
  • 1 Post By antoine.drouin
Thread: Rear brake wear indicator
    Junior Member antoine.drouin's Avatar
    May 2016
    5
    I noticed I am very much at the limit on the wear indicator for the rear drum brake so I ordered a new set of shoe brakes. Strangely, my current shoes look very much like the new ones and a mecanic told me it would be a waste of money to put the new ones in. I looked at the wear indicator and everything seems fine, there is only one position in which it can be installed so the indicator is not the problem. Anyone had a similar problem?
    Mar 2015
    Ynys Môn
    4,586
    It would help considerably if we knew the year of the bike, and the mileage – both of which you can put into your signature line
    This would save a lot of time in the future, and make any answers far more relevant (just a suggestion) ……
    Darth likes this.
    - Hidden Content
    May 2016
    5
    Indeed. Will look into adding to the signature.
    It's a 2003 with with 23000 km or about 14000 miles. Got it at 14000 km and never changed the shoes. Don't know about the previous owner.
    If I compare the old and new shoes, it seems I only went through ~15% of the brake material. Is this standard for brake shoes?
    Purple likes this.
    Mar 2015
    Ynys Môn
    4,586
    Yep - the rear brake friction material is tough stuff. I'd go with your mechanic, and stick the new ones on a shelf until they're needed .....
    - Hidden Content
    Senior Member Miaugi's Avatar
    Oct 2017
    Alfred, On
    463
    Quote Originally Posted by antoine.drouin View Post
    Hi Antoine and welcome to the forum. You could also add where you are located as it might be easier to hook up with other T-Dub owners. I'm guessing you're located in Quebec or Eastern Ontario? I`m near Hawkesbury myself.
    Senior Member RaZed1's Avatar
    Oct 2015
    293
    I've never paid much attention to the wear indicators on brake drums. I've had similar experiences several times- the indicator was near or past the "minimum" line, I pull the shoes, and they look practically new. Or I'll put the new ones in anyway, and the indicator is still virtually at the "replace" line anyway. Rear drum brakes last a VERY long time on motorcycles- I've pulled them on cruisers with 50k plus miles and they still look virtually new.
    While it's off clean up the drum and shoes with some brake cleaner, maybe scotch-brite the drum if it's dirty/caked with crud.
    Senior Member Darth's Avatar
    Nov 2013
    Timbercreek Canyon, Texas
    1,781
    And sand any glazing off the shoes' braking surface.
    "Faster, faster, faster, until the thrill of speed overcomes the fear of death."
    - Hunter S. Thompson
    Still, I rise!
    "Give a Damn"
    - C. M. Howe, Jr.
    Feb 2017
    Waretown NJ
    556
    did you buy OEM shoes?
    87 TW
  1. Brake fluid level a reliable wear indicator?
    By GCFishguy in forum Technical Help
    Last Post: 09-16-2017, 07:57 AM
  2. Rear Indicator screw plate???
    By macka in forum Technical Help
    Last Post: 11-07-2016, 12:29 PM
  3. front brake or rear brake for hill starts
    By mrx916123 in forum General Discussion
    Last Post: 03-27-2016, 06:29 AM
  4. Turn signal indicator out?
    By TW200_CA in forum Technical Help
    Last Post: 12-26-2012, 04:54 PM
  5. photo of brake pad wear braided lines
    By dubstep in forum Technical Help
    Last Post: 04-27-2012, 07:53 AM
