2001 TW is leaking gas out of the carb roverflow hose when running?
Results 1 to 10 of 18
Like Tree18Likes
Thread: 2001 TW is leaking gas out of the carb roverflow hose when running?
    Junior Member Sparky V's Avatar
    Apr 2019
    7
    Been moth balled a long time (6 years), have not remove carb yet...figure it is a float jam?
    Drained the crab, new gas...and leaking gas out of the crab overflow hose when running.
    Thanks
    GOF
    GOF is offline
    Senior Member GOF's Avatar
    Dec 2018
    Buffalo, NY
    378
    Only when running? Seems odd. If it is off and the petcock is open does it leak?
    Probably an issue with the float, needle, seat or combination.
    PlacerLode likes this.
    1988 Suzuki Savage
    1987 Yamaha TW200
    Senior Member Donzo's Avatar
    Oct 2016
    NorCal
    770
    As said, prob the float...
    Apr 2019
    7
    Quote Originally Posted by GOF View Post
    Hi GOF
    Sorry for the confusion...it runs out engine running or not...
    Taking it apart tomorrow to have a look.
    Thanks for the reply
    Apr 2019
    7
    Quote Originally Posted by Donzo View Post
    Hey Donzo
    Thanks for the post...yeah...got a schematic of the carb so tomorrow will be dissection time...
    Donzo likes this.
    Apr 2019
    7
    Let ya all know what I find.,..
    18,813
    Float Jam? That's not that the same as South Carolina's Drift Jam, world's largest floating music festival is it? drift jam.jpeg
    Don't know about crab overflow but the Drift Jam overflows with pretty girls.girls_of_2014s_ultra_music_festival_640_44.jpg
    Apr 2012
    Out West
    3,058
    Floats are very reliable you need a new needle seat assembly and while your in there clean or replace the pilot jet and replace the bowl o-ring
    The real risk is that gas will not only overflow the bowl to the outside it will also leak into your oil and thin is sometimes catistrophically
    check your oil level and don't run it if it's over full
    this is a very routine maintenance deal with all TW's
    Fred and Peterb like this.
    "It's Like Warm Apple Pie"
    Apr 2019
    7
    Quote Originally Posted by PlacerLode View Post
    Excellent info, thanks Palcer!
    Why would the needle seat assembly, pilot jet and bowl 0-ring fail/wear out?...o rings I understand but the others...thanks again...
    Frosty Hollow
    13,082
    Quote Originally Posted by Sparky V View Post
    Thanks
    I had a leaking float on my XT200 late last fall. Different carb than on the TW's but basically the floats operate the same. Fixed it this winter by checking the float bowl fuel level. Mine was out of adjustment by not allowing the needle valve not to "seat". I adjusted the float and all is good.
    It could also be as you suspect a sticking float. On my 2005 TW the o-ring on the needle valve seat assembly rotted away it this also allowed gas to freeflow out of the carb and even happened when I was riding it. Didn't realize what was going on at first as the overflow of fuel would stall the engine. In this case of the rotted o-ring, gas eventually flowed out of both the float bowl overflow tube and the other overflow tube (pipe).
    Needle seats aren't often the fault but very often replaced. I now have an extra brand new needle seat as I bought one thinking the adjustment wouldn't work.
    Donzo and elime like this.
  1. Pre 2001 front wheel on post 2001 tw
    By Jzarnesky in forum Technical Help
    Last Post: 10-06-2017, 10:32 PM
  2. Leaking Base Gasket OR Leaking Starter o-ring!
    By JS5owner in forum Technical Help
    Last Post: 11-08-2016, 08:37 AM
  3. Carb leaking gas when gas on and not running
    By Little Brute in forum Technical Help
    Last Post: 06-10-2015, 04:20 PM
  4. My 2001 TW was running fine until today...
    By Xaman in forum Technical Help
    Last Post: 04-15-2012, 09:43 AM
  5. Gas Leaking from Carb
    By lrotunda in forum Technical Help
    Last Post: 05-02-2011, 10:22 PM
