Cam chain adjuster
Results 1 to 4 of 4
Like Tree8Likes
  • 2 Post By Badgerflorida
  • 3 Post By buellzebub
  • 3 Post By Purple
Thread: Cam chain adjuster
    Member Joecabinetti's Avatar
    Dec 2016
    52
    Cam chain adjuster
    I know TW's are noisy and sometimes sound like a tin can filled with rocks. I was wondering if there would be any benefit to switching over to the old style manual cam chain adjuster. I'm pretty sure the older bikes had that. No?
    Jun 2017
    Milwaukee, WI
    1,285
    Yes the older bikes have manual cam chain tensioners. IMO switching from auto to manual would not make a significant difference. And I’m not sure they are a plug and play swap. If your bike has high miles and/or hard use the cam chain could be in need of maintenance or replacement but the auto adjuster shouldn’t really be a problem unless it’s not functioning properly.
    I’m guessing you inspected and adjusted the valves. If not, that is more often the source of the noise.
    admiral and Joecabinetti like this.
    01 SOLD
    96 SOLD
    89 restored SOLD
    89 (restoration in process)
    05 (restoration in process)
    03 SOLD
    04 in great condition
    Senior Member buellzebub's Avatar
    Oct 2015
    Breedon on the Hill, UK
    340
    Original Yamaha manual and auto tensioners are not interchangeable but there are Chinese manual versions available on eBay that will fit in place of the automatic type.
    admiral, Fred and Joecabinetti like this.
    Mar 2015
    Ynys Môn
    4,594
    Just because it says "automatic" doesn't mean it's working correctly - if you have doubts, check it ......
    Joecabinetti, Darth and Sthrnromr like this.
    - Hidden Content
  1. Chain adjuster change:
    By Prairierider in forum Performance and Customization
    Last Post: 08-24-2017, 12:18 PM
  2. Replies: 20
    Last Post: 12-03-2015, 01:58 PM
  3. manual cam chain adjuster
    By arrowsmith in forum Technical Help
    Last Post: 11-26-2015, 12:07 AM
  4. Cam chain/timing chain adjustment?
    By GaryL in forum Technical Help
    Last Post: 08-31-2013, 07:18 PM
  5. Welded snail adjuster thingy
    By lizrdbrth in forum Performance and Customization
    Last Post: 03-29-2012, 07:04 PM
