Clutch help advice
Results 1 to 5 of 5
Like Tree3Likes
  • 1 Post By Tweaker
  • 2 Post By Purple
Thread: Clutch help advice
    Junior Member Canoeman's Avatar
    Apr 2019
    3
    Clutch help advice
    I'm working on my daughter's newly aquired 1989 TW200. The clutch lever felt very soft, but was rideable and slipped a little in higher gears on occasion. I found the clutch arm return spring to be broke. I replaced the spring and adjusted clutch free play. The clutch now feels better, but doesn't fully dis-engage(meaning it kills the bike when going into first on an idle and when pushing bike in gear when turned off, there's quite a bit of resistance). I next drained the oil and pulled the clutch apart to inspect. The springs and friction discs were measured and within tolerance. Should I put it back together with fresh oil and try again? Is there something else I should adjust while it's apart? Not sure where to go from here but would like to get this resolved as the weather is getting nicer and I have a daughter that's ready to go ride.
    Dec 2015
    San Diego
    1,857
    I am not a clutch expert but I am pretty sure there is an adjustment you can make on the clutch itself. Check for the manual in the tech section and similar threads that show up below or a search.
    admiral likes this.
    Junior Member yamaha man's Avatar
    Nov 2018
    Ohio
    10
    I have a new 2019 tw200 and it does the same thing. Clutch is ok in top gear, no slipping but drags with clutch pulled in and motor not running. Normal for this bike.
    Hailey, ID
    3,275
    Switching to full synthetic (after 1500 miles on a new bike) will help. If the bike still does this after warm-up then the clutch needs adjustment.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Mar 2015
    Ynys Môn
    4,484
    Starting from cold, the TW will often stall when putting it into gear. Some people like to rock the bike back and forth with the engine off and the bike in gear (with the clutch pulled in) – personally, I find that if you blip the throttle before stuffing it into gear (grabbing a fistful of front brake at this point is “advisable”), it’s enough to break the plates free
    Changing to synthetic is also a way around the problem, though the “sticky plates” start to come back after a thousand or so miles. In short, there is no one simple cure – it comes with the bike, so get used to it
    Though, as your bike is a 1989, it is possible that the cork plates are “gunked up” beyond redemption, and even swelling. A cheap thing to try, would be to replace those cork plates, and see if it improves the situation, especialy the “slip at speed” situation. Cork may not “absorb” oil, but 30 years later, the coating of oil defeats the friction, and causes swelling
    So in theory – you should some improvement when pushing it in gear with the engine off (on a warm engine), but still expect to have to blip the throttle before putting it into gear from cold
    The clutch action itself on a TW is light when compared to say a Kawasaki 550, but as long as it works, don’t sweat it ……
    Sthrnromr and Xracer like this.
    - Hidden Content
  1. TW Clutch Renewal Advice Wanted
    By rogerww in forum Technical Help
    Last Post: 02-13-2018, 04:28 PM
  2. Replies: 2
    Last Post: 09-04-2014, 08:12 PM
  3. 09 TW200 Wont start HELP HELP HELP PLEEAASSE
    By island in forum Technical Help
    Last Post: 08-20-2014, 07:53 AM
  4. Clutch Engagement vs Free play in clutch lever
    By Jay-2 in forum Technical Help
    Last Post: 04-09-2014, 06:24 AM
  5. Need advice on clutch behavior!
    By Gator in forum Technical Help
    Last Post: 09-06-2012, 04:34 PM
