first oil change, quick question
Results 1 to 4 of 4
    Member russ5415's Avatar
    Jan 2013
    louisiana
    58
    hey guys, i have about 75 miles on my bike and was about to change the oil, but decided to put it off. I figured i'd leave the break in oil in just a little longer. I have a bottle of mobil 1 synthetic in hand but got to reading that some people recommend not to go with synthetic for the first oil change. Not trying to start another which oil debate, just trying to find out if there is a reason to not use synthetic for the first change.
    Senior Member rm_hm's Avatar
    1,619
    Here are the last few times the "When to switch to synthetic question" was asked
    http://tw200forum.co...5/ShowPost.aspx
    http://tw200forum.co...4/ShowPost.aspx
    http://tw200forum.co...1/ShowPost.aspx
    Qwerty's words of wisdom on break in are HERE post #6 and HERE post #5
    Oh and then this is this old guy's advice
    http://www.dansmc.co...ine_breakin.htm
    Which way is best? Beats the hell outta me
    Senior Member stephenmarklay's Avatar
    Mar 2012
    Spokane, WA USA
    493
    I asked the same question Russ. The thought is to stay with non synthetic to seat the rings. This just means to better mate the rings to the walls during this break in. I read that a synthetic may glazes the surfaces before they actually wear and mate well.
    2011 TW200: Protaper Fat Bars, IMS Pegs, Cyclerack, Moose Racing Tail Bag, Cyrca Handguards, VStrom Mirrors, Jimbo Shield, Oxford Heated Grips, ProCycle 15k spring, 2x2cycles rack, seat concepts, Cyclops Adventure Sports LED conversion
    2014 BMW F800GS
    2007 BMW R1200R
    Jan 2013
    louisiana
    58
    Thanks for the quick replies guys. I had read most of those posts which is what got me questioning the synthetic in the first place. Most of those post are going on 5 years old and had varying opinions so i wondered if something had changed since then. Rich, somehow i overlooked the last two you quoted from qwerty, that is definitely the clearest break-in advice i've seen so far. The owner's manual suggestion of 'avoiding prolonged operation' over a certain throttle level leaves a lot to be interpreted, like their definition of 'prolonged'. Thanks again guys.
  1. Need some help quick! Oring question?
    By bogey72 in forum Technical Help
    Last Post: 05-20-2013, 07:42 AM
  2. Oil Change Question – ease my worry
    Last Post: 11-07-2012, 10:05 PM
  3. Help quick air filter question
    By mtngirl in forum Technical Help
    Last Post: 08-21-2012, 12:48 PM
  4. Quick base gasket question
    By Larry in forum Technical Help
    Last Post: 07-22-2012, 09:11 PM
  5. question on oil change & break in.
    By birdmove in forum Technical Help
    Last Post: 09-01-2011, 07:18 PM
