Pulling Flywheel
Results 1 to 10 of 11
Like Tree10Likes
Thread: Pulling Flywheel
    Junior Member kplupton@msn.com's Avatar
    Sep 2018
    Hailey, ID
    Pulling Flywheel
    Need to pull the flywheel on my TW 200. I read on here somewhere that the rear axle is the same thread size as the flywheel. The axle threads in but how do I keep the flywheel from turning?
    Pleasanton, CA
    5,635
    Put the bike into gear.
    If you are using an impact wrench, that should provide enough reisistance to break it free.
    Before I got an impact wrench and was trying to use a breaker bar, I had problems with the rear wheel turning. I solved this problem by putting a length of 2x4 through the rear wheel spokes/swingarm to keep the wheel from turning.
    Fred and admiral like this.
    Oct 2018
    Rural, South Carolina
    630
    Haven’t done it on a TW, but on other bikes the impact wrench was the method that actually worked well.
    admiral likes this.
    2010 TW200 - The Goat
    Triumphs
    ATVs
    18,424
    +1 on impact wrench to both remove and re-install flywheel using the rear axle bolt.
    admiral likes this.
    6,933
    Rather than pulling the rear axle to remove the flywheel, why not go to the hardware store and buy a bolt the same diameter and a lot shorter to do the same thing? It seems to me removing the rear axle is a lot of extra work.
    buellzebub and admiral like this.
    Senior Member buellzebub's Avatar
    Oct 2015
    Breedon on the Hill, UK
    324
    +1
    IIRC it's M16 x 1.5mm fine pitch and about 40~50mm long should do it
    And I used one of these, only £20 (about $25) eBay item no. 201229075988, to hold the flywheel.
    admiral, elime and Sthrnromr like this.
    Feb 2017
    Waretown NJ
    535
    why make things harder than they need to be?
    Order one on ebay or amazon. It will be at your door in 2 or 3 days
    https://www.ebay.com/itm/Motion-Pro-...72.m2749.l2649
    CJ7Pilot likes this.
    87 TW
    18,424
    ...and use the impact wrench.
    You don't really need to use one, you just need a good excuse to finally buy an air compressor and start collecting some air tools.
    Oct 2018
    630
    Haha hey, they are very useful
    Triumphs
    ATVs
    GOF
    GOF is offline
    Senior Member GOF's Avatar
    Dec 2018
    Buffalo, NY
    210
    Air tools are nice. But I picked up a Ridgid 18 volt impact wrench. It's nice not to be tied to an air hose.
    1988 Suzuki Savage
    1987 Yamaha TW200
  1. Popping and not pulling, carb troubleshoot? Help!
    By SDTW200 in forum Technical Help
    Last Post: 09-13-2014, 10:14 AM
  2. Close to pulling the trigger
    By DGrav in forum General Discussion
    Last Post: 03-30-2014, 09:52 AM
  3. “…and they’re neck an’ neck. Wait, the TW is pulling ahead…”
    Last Post: 10-16-2013, 07:03 PM
  4. Pulling a trailer
    By chevyluver in forum General Discussion
    Last Post: 04-10-2012, 10:41 AM
  5. TW pulling a Trailer??
    By bangkokbonk in forum General Discussion
    Last Post: 02-17-2012, 08:17 PM
