ditching the battery and electrical help - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Like Tree17Likes
Thread: ditching the battery and electrical help
  1. #11
    Junior Member JTG671's Avatar
    May 2019
    8
    I’ve been looking up post about how many are able to start and run without a battery, just none of the lights are working
  2. #12
    Senior Member Stufidmotard's Avatar
    Jun 2017
    Greenleaf, Idaho
    121
    Mine won't kick over without a battery.
  3. #13
    Apr 2013
    385
    the jap guys remove it when they do hollow mods, i think they replace it with a battery tender? not 100% on the name but you will be able to find it on webike site, will probably give you a description and maybe from that you can find something similar on Ebay etc.
  5. #14
    May 2019
    8
    https://www.tw200forum.com/forum/tec...l#/topics/7874
    https://www.tw200forum.com/forum/tec...s/59386?page=2
    These are the two post I found of simplifying the wiring. The difference between those and my plan is I’m wanting to remove all the lightings and battery if possible. If any electrical gurus on here can confirm if these would work.
  1. Replies: 19
    Last Post: 04-24-2019, 07:44 PM
  2. Tw200 Wont Charge Battery (ELECTRICAL ISSUE)
    By cappamura in forum Technical Help
    Last Post: 10-22-2018, 09:50 AM
  3. New battery and tw will not maintain a charged battery
    By Mr.wiggle in forum Technical Help
    Last Post: 06-27-2016, 08:06 AM
  4. Electrical gremlin. Kills battery
    By Jd87 in forum Technical Help
    Last Post: 09-04-2014, 11:07 AM
  5. No electrical on '87 after battery tender...
    By VitaBrevis in forum Technical Help
    Last Post: 01-19-2012, 06:17 PM
