Front brake sticking - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Like Tree40Likes
Thread: Front brake sticking
  1. #11
    GOF
    GOF is offline
    Senior Member GOF's Avatar
    Dec 2018
    Buffalo, NY
    210
    I would go ahead and lube all the cables. An ounce of prevention and all that. I would also pull the front wheel and inspect the bearings, shoes, hardware and lube what needs it and replace anything that falls short of optimal. Easy to do and could prevent problems down the road.
    1988 Suzuki Savage
    1987 Yamaha TW200
  2. #12
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,850
    The front brakes on mine have always required a flick of the lever to put them at the proper disengaged position. It stops great but I have just got used to the flick of the lever and no problems.
  3. #13
    Senior Member Xracer's Avatar
    Lake Placid,Florida
    3,701
    Put some lube on that brand new cable and a dab of grease on the pivot pin.
  5. #14
    Sep 2014
    Mamaroneck, NY
    2,173
    Florida bike?
    Check the wheel bearings. A failed bearing is zero fun. Can be quite painful too.
    Ken and jtomelliott49 like this.
  6. #15
    Member UstaKood's Avatar
    Jan 2019
    Gun Lake Michigan
    36
    Had the same issue . I ended up pulling the cable out and cutting the nylon off the cable on both sides . It worked !
    New cable would be best .
    jtomelliott49 likes this.
    Scott
  7. #16
    Senior Member mrlmd's Avatar
    1,153
    The new cable is supposed to arrive today - real quick shipping and delivery. I'll lube it up before installing it and let you know how it works.
    Then, the clutch cable, even though it's working fine. Already did the throttle cables.
    Xracer, UstaKood and jtomelliott49 like this.
  8. #17
    1,153
    New cable in and it works great. Wheel spins freely, no binding of the brake or bearings, the whole problem was the cable sticking in the sheath and not sliding to release the brake.
    Happy again.
  9. #18
    Lake Placid,Florida
    3,701
    So what are you going to tear into next that we can help you out with?
  10. #19
    1,153
    I'm sure I'll find something. This is, after all, a 19 year old bike but it still runs fantastic.
    And I have to find some reason to talk to you guys, right? Isn't that why we're all here?
  1. ‘94 shift lever sticking
    By Rhodekoff in forum Technical Help
    Last Post: 11-30-2017, 08:52 PM
  2. Rear brake sticking
    By 1RobAusdemore in forum Technical Help
    Last Post: 08-06-2014, 09:52 PM
  3. Sticking Rear Brake
    By admiral in forum Technical Help
    Last Post: 02-25-2014, 11:36 PM
  4. Help! Tire sticking at certain point in rotation
    By Olydog in forum Technical Help
    Last Post: 05-09-2012, 10:13 AM
  5. Throttle sticking
    By RingSteel in forum Technical Help
    Last Post: 02-29-2012, 01:20 PM
