fuel hose routing
Results 1 to 8 of 8
    Senior Member bikerjosh's Avatar
    Walnut Creek, CA
    1,066
    Howdy gentlemen. Trying to re-run my fuel line due to tough routing using a xt350 tank. Looked for a re-enforced or anti-kink fuel line given the tight curve I need to make. Haven't found anything, now I'm toying with the idea of bending a hard(rigd) brake line and using that that with short sections of fuel line on each side. Run is pretty tight, see pics.
    Any ideas?
    thanks
    Not all men are capable of greatness, but all possess toughness.
    2001 TW a mod or two maybeHidden Content
    Desert, SoCal
    7,369
    Interesting. On my steel XT tank the petcock is only slightly behind the head. It appears that the Clarke tank's petcock sits a good couple inches further rearward.
    Acerbis sells a left-exit petcock which cold be one solution if there's enough room. It's intended to go on the right side of their tanks with two petcocks.
    1,110
    Will a longer piece of hose making a larger radius bend work better?
    Edit: I don't think it will. I just went out to the shop and fiddled with a piece of hose. If I could delete the post I would have.
    Nov 2011
    norcal nutjob
    3,310
    hey josh,
    what happened to the active pump xt225 tank? decided less was more?
    i'm always inspired by your bike and the ideas you have, i'm sure you'll figure out a fix for this.
    i'm out of commission for a month or so, but let me know when you want to hit hollister.
    joe
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    Use a longer hose and loop it.
    Senior Member xdac's Avatar
    Mar 2011
    Gilbert AZ
    1,076
    I have the same problem with mine..hard to run a fuel filter too
    6,975
    Quote Originally Posted by joe band View Post
    hey josh,
    joe
    If you guys go in the middle part of the week let me know and I'll go too.
    Walnut Creek, CA
    1,066
    Yep, tried the longer hose route but outlet of petcock causes the hose to hit the frame, so you have to run it on the outside and back in. Might have to bend up a peice of rigid brake w/single flairs and run two short rubber hose sections.
    josh
  1. Need help with cable routing
    By Ayers Garage in forum Technical Help
    Last Post: 07-19-2012, 03:46 AM
  2. Fuel line routing
    By Joe in forum Technical Help
    Last Post: 01-08-2012, 04:24 PM
  3. coasting enricher hose
    By TWhog in forum Technical Help
    Last Post: 09-28-2011, 09:16 AM
  4. fuel hose sizing
    Last Post: 08-31-2011, 08:35 PM
  5. Battery breather hose
    Last Post: 07-06-2011, 06:12 AM
anti kink fuel line
fuel lines
