2017 TW200 Clutch Issues
Results 1 to 7 of 7
    Junior Member DMCG's Avatar
    Feb 2019
    20
    I am having a problem with my clutch. Specifically, the friction point seems to be almost when the clutch lever is fully released. It also seems as though the clutch may be slipping at high revs. The bike has about 800 miles on it. I recently changed the oil and used Yamalube recommended by the dealer. I tried playing with the free play adjustment knob, but that was no help. Any thoughts?
    Apr 2012
    Out West
    2,999
    all perfectly normal re the release or engagement point if that is what you mean by "friction point" but slipping not normal obviously
    many people seem to get befuddled by the TW's clutch lever releasing at the very last point of lever travel or disengaging with the first touch of the clutch lever I often see it on peoples faces when they take their first test ride and they are anticipating the bike starting to move as they are releasing the clutch to the point where they seem surprised when it actually engages the clutch lol
    "It's Like Warm Apple Pie"
    Senior Member Ski Pro 3's Avatar
    May 2014
    El Dorado, California
    790
    The stock clutch springs are weak. After market springs will allow for some range in clutch engagement. Weak springs will also cause high rev slippage.
    The bear slayer!
    Feb 2019
    20
    I don't think it is normal. At least I don't remember it being that way for the first 200 miles that I rode the bike.
    Feb 2019
    20
    Where do I get stronger clutch springs for the bike?
    Oct 2018
    Rural, South Carolina
    630
    Quote Originally Posted by DMCG View Post
    Barnett or EBC should do it, or even Vesrah. Procycle, eBay or Amazon.
    2010 TW200 - The Goat
    Triumphs
    ATVs
    Senior Member SHAG's Avatar
    Oct 2013
    Bradford, Pa
    936
    Check the threads at the bottom of the page
    05-BMW1200GS- Rock Red 106k miles
    2013-TW200 - 8k- miles
    2018 X-MAX - 5k- miles
  1. Replies: 27
    Last Post: 02-21-2016, 09:09 PM
  2. clutch issues
    By joshuadt in forum Technical Help
    Last Post: 08-01-2015, 03:21 PM
  3. Clutch issues..
    By oldmercman in forum Technical Help
    Last Post: 03-31-2015, 03:34 PM
  4. clutch shifting issues
    By Trail King in forum Technical Help
    Last Post: 05-06-2014, 03:07 PM
  5. Clutch Engagement vs Free play in clutch lever
    By Jay-2 in forum Technical Help
    Last Post: 04-09-2014, 06:24 AM
