Diaphragm on side of TK Carb
Results 1 to 4 of 4
Like Tree9Likes
  • 6 Post By RockyTFS
  • 1 Post By jbfla
  • 2 Post By GaryL
Thread: Diaphragm on side of TK Carb
    Junior Member GNolan's Avatar
    Feb 2019
    Clarkston MI
    21
    Hello Everyone,
    Can anyone tell me what the Diaphragm does on the TK Carb? Theory and/or purpose of it and how it works? I know it is the fuel shut off or something like that and vacuum operated. It opens and closes a valve or bypass of sorts. Please educate me to understand how this operates.
    Thanks, Greg Nolan
    Hailey, ID
    3,276
    I wondered too. I found this:
    COASTING ENRICHER - Feeding a Closed Mouth
    You're blasting down the trail and you see a hairpin coming up, so you close the throttle. This closes the butterfly valve. You and your 400lb baby (the bike, not the other love of your life), are still rolling with inertia, keeping the engine revs high. Now it can't get the mixture it's trying to suck in because the butterfly valve is closed, blocking the air flow. To compensate for this there's an air jet in the lower diaphragm chamber that transfers ambient pressure to one side of the coasting enricher's spring loaded cut off valve. The excess vacuum in front of the butterfly valve is transferred to a drilling that leads to the other side of the cut off valve. This sucks it open, allowing the pilot jet to feed more fuel to the engine preventing an overly lean condition. (Pop. Pop. Pop.)
    This isn't a TK carb, but the principle is the same.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,382
    Thanks, Rocky.
    Best explanation I have seen.
    Here are the corresponding inlet holes on the TK cv carb:
    jb
    Sthrnromr likes this.
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    7,920
    Good explanation however Gnolan has an old style TK carb that does not have the flap. I call this diaphragm a deceleration circuit that probably performs the same function but in the old style carbs it works a little different. I know when this system is not functioning properly the bike will back fire on deceleration which probably indicates the carb is getting too much fuel when none is being called for.
    jbfla and Xracer like this.
    1987 Yamaha BW350 Big Wheel
  1. Rubber diaphragm found mashed in and causing carb issues
    By docjekyll2002 in forum Technical Help
    Last Post: 06-29-2015, 12:57 PM
  2. Diaphragm on early model carb
    By Alwood in forum Technical Help
    Last Post: 04-24-2014, 09:19 AM
  3. Diaphragm installation sequence.
    By joeguy in forum Technical Help
    Last Post: 04-02-2014, 03:24 PM
  4. TK Carb Photos and Parts Identification
    By jbfla in forum Technical Write-Ups
    Last Post: 06-06-2011, 02:34 PM
  5. Lazy Man's Teikei (TK) Carb Cleaning
    Last Post: 12-08-2010, 10:48 PM
