Ticking Noise
Results 1 to 10 of 11
Like Tree2Likes
Thread: Ticking Noise
    Member lowtechboy's Avatar
    Aug 2012
    Orange VA
    39
    I have a quick question, my t-dub has recently developed a rather loud ticketing noise. So I decided to adjust the valves but when I adjusted them it seemed like the exhust tappet had some play in it. not a lot but enough to notice, could the loose tappet be the reason for the loud ticketing noise? If it is would it hurt to drive it as it is, I did adjust the tappet to between .004" to .005" with the max being the widest point in the play...
    Thanks for any advise in advance.
    Ephrata, WA
    1,125
    What year and how many miles?
    As long as your tappet gaps are within spec you should be fine. From what I've gathered, these engines are naturally noisy.
    1990 TW200
    Senior Member mrbracket's Avatar
    Jul 2012
    Springtucky, Orygun
    631
    When you say "I did adjust the tappet to between .004" to .005" with the max being the widest point in the play" do you mean you made the adjustment with the engine at Top Dead Center on the Compression Stroke? If not, do it again.
    It's odd that it came on suddenly?? Are you low on oil? Hopefully you didn't end up with one of those faulty oil filters???
    You've got a friend in the Bracket Business! Hidden Content
    Get your TW200 Parts at ProCycle! Hidden Content
    Aug 2012
    Orange VA
    39
    Sorry I didn't post the year and mileage, I thought about it after I hit post...
    Its a 94 with 2596 miles on it. I got it with around 900 miles on it so I am just getting through the break in period I believe. I just had the oil changed in it and made sure it had the right filter with the four holes in it. On the thought of oil changes though I believe I am burning oil and didn't realize it so it ran "really low" on oil before I caught it. ( I hope that isn't the problem... )
    When I adjusted the Valves I didn't use the markers with TDC, ( didn't know they were there... ) I will try to readjust them with the marker and see if that helps.
    I am new to working on motorcycles but I figured I would give it a try anyways since the noise was already there.
    Thanks again for the advise.
    Sep 2012
    Northwestern Oregon
    1,092
    Quote Originally Posted by lowtechboy View Post
    Don't forget to look in the service manual (available online) and this sticky thread here on the forum: Valve Adjusting
    Aug 2011
    Cayce, SC
    3,109
    You must adjust the valves at tdc. It is very easy to do on these tw's. There will always be a ticking noise from single cylinder engines but keeping the valves in spec will limit the noise.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Ephrata, WA
    1,125
    +1
    TDC and a COLD engine is a must.
    1990 TW200
    6,975
    My '87 TW with 20K miles on it has a horrible ticking sound and it seems to be getting worse. I have adjusted the valves many times but no good.
    The ticking is worse when the engine is hot however it goes away after a hard workout, that is when it is real hot, but comes back as it cools down a little. I am getting ready to replace the base gasket so I will inspect the piston and valve guides and see if they are OK. Reports to follow.
    Senior Member arrowsmith's Avatar
    Missouri
    673
    My 91 makes a lot more noise than my 03.
    Member apophis13's Avatar
    Aug 2015
    denver
    64
    I pulled the timing chain adjuster off my 2006 today. The cause of the ticking is VERY clear. The end of the pushrod is a free floating cap. I can make the cap tick in my hand easily. I see no way of making it not free floating (which might be part of its design). Anyway, I hope this solves a mystery. The cap TICKS.
  1. Replies: 14
    Last Post: 05-22-2012, 09:38 PM
  2. Loud ticking noise after topend job
    By SURVEYWATERS in forum Technical Help
    Last Post: 01-22-2012, 04:01 PM
  3. valves ticking bad
    By jimbo slice in forum Technical Help
    Last Post: 06-07-2011, 07:38 AM
  4. Weird Noise
    By wvhunter in forum Technical Help
    Last Post: 04-23-2011, 08:13 PM
  5. Front sprocket noise?
    By Little Valy in forum Technical Help
    Last Post: 10-14-2010, 10:05 PM
ticking noise
tw200 ticking noise
tw200 ticking sound when hot
yamaha tw 200 noisy tappets
